When I turn my key on, before I get to position to crank the motor a buzzer alarm sounds off under the dash, what causes the alarm to turn on?
22ve 2006
Normal.....no oil pressure.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I know this beep is normal but is it due to no oil pressure? Mine stops after a few seconds. I always thought that it was a warning beeper to warn you to look around and clear the boat and prop before starting the motor.Originally posted by chpthril View PostNormal.....no oil pressure.Wake Up or Stay On Shore!
Could be, but theres still no oil pressure til you start the engineOriginally posted by Wakeman22 View PostI know this beep is normal but is it due to no oil pressure? Mine stops after a few seconds. I always thought that it was a warning beeper to warn you to look around and clear the boat and prop before starting the motor.
J/K, I do know its the same tone that is put out when the oil pressure drops, but it could be used to indicate a number of things.
You are correct that it is the same tone for many different warnings. Now I am curious to know. I need to go find my owner manual.Originally posted by chpthril View PostCould be, but theres still no oil pressure til you start the engine
J/K, I do know its the same tone that is put out when the oil pressure drops, but it could be used to indicate a number of things.Wake Up or Stay On Shore!
