Was driving the boat and the rope got caught in one of the wakeboard racks, I didn't see it because the bimini was in the way, spotter didn't see, and person being towed didn't either, so the rack broke clean off the base plate when they tried to get up... just need the forks that mount to the swivel base plate... Base plate says Tige, it's factory. However, called my dealer and a couple others in the region and got no help. Called Tige direct and they have since changed manufacturers with their newer boats, so does anyone have a rack available for a 2007 24ve or know who manufactured them?
Need Factory Wakeboard Rack for 2007 24ve
Did you loose the fork into the lake? The reason I ask is because I have one more fork, but no rubber inserts for tie-downs, just fork. I will go and look just to double check. If I have one, it's yours for the shipping.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I thought they went under? Or was it someone else I'm thinking of. It's odd that they are not available from Tige as the same looking rack is still offered on the "E" series tower. There are plenty of those out there covered under warranty, what would Tige's solution be if one was in need of replacement for a warrantable failureOriginally posted by da.bell View PostHe could get the rubber inserts from Wake-Designs.
Is it me or is this year the year to have wakeboard forks ripped off??? Seems like a ton of people have done this, this year.
Their website is still up.
http://www.wakedesigns.com/
Accessories:
http://www.wakedesigns.com/item.asp?iid=41
Wakeboard Racks
yup, whole thing went sploosh straight to the bottom of the lake, luckily didn't hit the boat on the way down... here's are the pics... if they match I'll buy it. all the after market ones I've found have a different size mounting plate so no luck there...
#1:
#2:
#1:
[URL="http://65.197.168.66/towel-l.jpg"]
#2:
[URL="http://65.197.168.66/towel-r.jpg"]
Wow, you took off both forks
Lucky for you I actually have 3 forks left, but no rubbers on any of them.
hey CHPThril...any chance you've got one Tige 24ve wakeboard rack fork left? I took my father-in-law's boat out and the wakeboard rope caught on it and one flew to the bottom of the lake. It must have been barely hanging onto the plate, because there was no pressure on the line when it came off. Either way, I'm having trouble finding them so if you have one or know where I could get one I would greatly appreciate it.
