Here's my progress so far. I installed the flanges so they pointed up and the TAPS clearance is real close. I'm calling FAE tomorrow to make sure it is right and then I will remove the flanges and install a second time with the 3M 5200. Enjoy the pics so far.
FAE Install
Looks like mine. I will wait to post pics of it mounted with the whole thing completed though. I am redesigning the supports just a little. I plan to have it done today if I can get the boat to my friends fab shop.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
I don't think you want to use 5200 on the flanges. You should just be able to install the screws back into their original holes. If anything, use some silicone or you will never be able to remove them again. If they ever fail (as mine did), you'll want to be able to remove them.Originally posted by evil0ne View PostHere's my progress so far. I installed the flanges so they pointed up and the TAPS clearance is real close. I'm calling FAE tomorrow to make sure it is right and then I will remove the flanges and install a second time with the 3M 5200. Enjoy the pics so far.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Does it dramatically reduce engine noise? Are they hard to install?
Thought about installing one of these, not so much for the Carbon Monoxide but for the fact that my engine is loud. The engine noise cuts into my tunes while wakeboarding.
However, its a double edge sword since I like the sound of my engine. Ah decisions...
Yes! The difference is dramatic. It's like putting your boat in stealth mode.Originally posted by Matt Garcia View PostDoes it dramatically reduce engine noise? Are they hard to install?
However, its a double edge sword since I like the sound of my engine. Ah decisions...Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
X2.Originally posted by dogbert View PostI don't think you want to use 5200 on the flanges. You should just be able to install the screws back into their original holes. If anything, use some silicone or you will never be able to remove them again. If they ever fail (as mine did), you'll want to be able to remove them.
I put a little silicone on mine for extra hold and sealing and did not have a problem after 2 seasons.Be excellent to one another.
The reduction of fumes is the best part. It makes riding in and behind the boat so much nicer. The noise reduction is pretty cool as well.
I'm surprised you don't have one yet.You'll get your chance, smart guy.
I 5200'd mine 18 months ago and had no trouble removing it a couple of months ago.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I most certainly would put 5200 in the holes for the screws. This way you are sure not to get any leaks through the screw holes. I will have mine done today and then post some pics. After work I am heading to the fab shop to finish it up.www.automarinecare.com CWB, ACME, FlyHigh, Merc Marine, PCM, Marine-power, WETSOUNDS, HSE Volume Controls, Kicker, Sony, Samson Sports, and many other marine parts or accessory's.
