check-valve in the bilge outlet cures that. Many new pumps come with them and some pumps can have one installed in the outlet.
2016 RZX bilge pump question
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by chpthril View Postcheck-valve in the bilge outlet cures that. Many new pumps come with them and some pumps can have one installed in the outlet.
An alternative, if you want to share a single thruhull, is a check valve between each pump's outlet and its (usually) Y connection to the shared thruhull. This prevents either pump from using the other one as a path back into your bilge, and thus the water only has one place to go - overboard - even if only one pump is working.
EDIT: However, I still prefer the entirely separate pump approach. Bilge pumps can seem dull and uninteresting until you really need them. If you carry a standalone ballast pump (always a good idea in case a drain pump dies) it can double as an emergency bilge pump. We carry a standalone, 12V-outlet-powered Tsunami with a long hose for exactly these reasons. But how ever it's done, it's always a good idea to have an entirely separate method to get rid of ballast or bilge water if something unexpected happens.Last edited by IDBoating; 05-22-2018, 08:55 PM.
With a 3-wire pump, the auto side of each pump will be separate circuits all the way to the constant B+.
The manual side can easily be wired to be separate but yet powered by one manual bilge switch. This might be the best way to go when the manual bilge function is digital through a tige touch or similar, when there are no manual rockers at all.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by chpthril View PostWith a 3-wire pump, the auto side of each pump will be separate circuits all the way to the constant B+.
Bottom line: Folks need to do what works for them and gives them the safety and security they feel good about. We each have our own standards for such things. To me, bilge pumps are safety equipment so I'm a bit less cavalier about how I wire and plumb them. It's all good!
Unless they share a fuse or circuit breaker back at the under-dash panel.
Switch failures are rare. Even with a single pole, you can supply 2 pumps, each with its own fuse right off the switch output. One pump failure would not effect the switch or the other pump.
With a PCB output like the medallion or murphy, use a relay to supply both pumps and a fuse for each, right off the relay. Same results.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by chpthril View PostAlso, with the auto-bilge circuit, you would want to wire battery direct to insure bilge function even if the main battery switch was off. So it would not be wired to the helm BUS. The auto side gets its own fuse and direct to battery or constant.
