If you go that route, ask them about a group buy. Anyone into self diagnostics should have at least that. Seems like a fair price.
Help.. Boat will not start
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by UNSTUCK View Postif our posterity ever run into a low voltage problem at the pump, like your friend's boat did, our posterity needs to know not to look at the ECM.... If your fuel pump does not use a relay (I haven't seen this), the ECM could be suspect.
I get the distinct impression from your responses that I've offended you in some way with the information I shared. Not sure how or why, but I apologize for whatever I said that offended you. I was just offering assistance in case it helps someone either now or in the future. It's pretty common here on TigeOwners to share fixes and data and helpful tips, I hope that's still acceptable.
X2 on the group buy. Side note, last year when my boat wouldn't start it ended up being the crank sensor. Turns out you need a scan tool to re-train the ECM to the new crank sensor. Weeks waisted because I simply didn't have the right tool. You have found the same diagnostic sheets I was using. It was helpful but without that tool there is only so much you can do.Sometimes you have to do what feels good, rather than what feels right.
Originally posted by alwayssummer View PostX2 on the group buy. Side note, last year when my boat wouldn't start it ended up being the crank sensor. Turns out you need a scan tool to re-train the ECM to the new crank sensor. Weeks waisted because I simply didn't have the right tool. You have found the same diagnostic sheets I was using. It was helpful but without that tool there is only so much you can do.
Sent from my XT1080 using Tapatalk
Originally posted by IDBoating View PostThe boat in question has a Mercury engine, and its ECM directly drives the HPFP. While I agree that I've seen more relays than ECM's driving pumps, Mercury isn't exactly a small unknown vendor.
Sorry to have given you the impression that you offended me. You haven't in the slightest. I'm just trying to help prevent a misdiagnosis and clear up some information that may be misleading or confusing to anyone who runs into this problem in the future.
I called the dealer and talked to their master tech he has no idea what has both the fuel and ignition system shut down. Said there is zero chance the crank/cam sensor could be causing it. Said they would put the scan tool on it and diagnose the problem for $75
Originally posted by dustinsnipes View PostI called the dealer and talked to their master tech he has no idea what has both the fuel and ignition system shut down. Said there is zero chance the crank/cam sensor could be causing it. Said they would put the scan tool on it and diagnose the problem for $75
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by UNSTUCK View PostDo you mean dustinsnipes boat as the boat in question or your buddies? dustinsnipes boat has an ECM that directly drives a relay that drives the fuel pump.
My point was that both relay and non-relay powered systems are out there, and while we're having a discussion about problems powering fuel pumps it might be useful to mention both.
Been following this closely and just thinking out loud. Same boat/Motor/Year what are the chances that this could be caused by the ignition itself? When I turn my key to ACC. prior to start I listen for the LPFP to kick on before I fire it up. IF the ignition is bad, IE not sending power to the ECM to close the relay the pump wouldn't run. Also may explain why your getting poor or no spark anymore as well if the ignition is deteriorating. I may be way off base here but just a suggestion, ignitions are $30 vs. 1K+ for new ECM.My life's journey is not ending up looking pretty, its sliding in broadside, used up, worn out, screaming "What a Ride"
Originally posted by dustinsnipes View PostI never heard of having to reprogram for a crank sensor but yeah I'm starting to feel like I'm going in circles. May end up taking the boat to the dealer and see if they can diagnose the problem
Sent from my XT1080 using TapatalkMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by Thegerman618 View PostBeen following this closely and just thinking out loud. Same boat/Motor/Year what are the chances that this could be caused by the ignition itself? When I turn my key to ACC. prior to start I listen for the LPFP to kick on before I fire it up. IF the ignition is bad, IE not sending power to the ECM to close the relay the pump wouldn't run. Also may explain why your getting poor or no spark anymore as well if the ignition is deteriorating. I may be way off base here but just a suggestion, ignitions are $30 vs. 1K+ for new ECM.
This seems more and more like a grounding issue. Maybe all your connections are tight, but you could have corrosion inside the wire jacket that you can't see. I'd take apart every ground terminal in the engine Bay Area and ohm them back to the battery or to its connector at the ecm.
[QUOTE=UNSTUCK;758809]A few pages back he said he has power to the 86 terminal in the relay. This power comes from the ignition switch. So we know at least that part is good. And when he jumped the ground wire of the relay the engine ran. QUOTE]
Sorry I must have missed that post, was just my 2 cents for what I was reading. I am not super smart on this stuff, just trying to help in case it wasn't thought of.My life's journey is not ending up looking pretty, its sliding in broadside, used up, worn out, screaming "What a Ride"
Tigé Jedi
- Jul 2010
- 4303
- TN USA
That sucks. When they say "bad ECM", precisely what do they think is "bad" about it? I'm asking because strictly speaking my friend's boat had a bad ECM (according to the tests in the service manual) but we were able to keep it running by actually understanding the problem.
Just trying to save you time and money.
