Hey newb here got a 22V today and the rocker switches are faded out anyone have a picture so I know what they are? Thanks.
04 22V Rocker Switches
Here is a pic of my '05, not sure if they are the same. I think Bakes has them available. http://www.bakesmarine.com/
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
I had some custom rocker switches made from these guys and they are way cool.
https://www.otrattw.net/Be excellent to one another.
yep, if the actual switch is functional, these guys can do the labeled actuators for you. They have a on of standard ones, will do custom text edits to existing standard actuators as well as your own custom stuff. They do my ballast switch actuators as well as I just order 16 friday that are a mix of standard and custom text for a 32' center console that im redoing the helm on.Originally posted by talltigeguy View PostI had some custom rocker switches made from these guys and they are way cool.
https://www.otrattw.net/Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I actually have OTRATTW saved in my bookmarks also for some off road switches I was looking at a couple years ago. Are the switch tops/rockers universal to most switches or do they only mate with certain switch bodies? Which style rocker would be needed to replace the switches in the above pic? The Contura V line?
Most marine build use the same witch body, so yes, most of the actuator styles are universal. However, OTR cant etch all he different actuator styles. So if a boat has a style they cant do, its worth it to upgrade all them to a new style.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
