Santa Barbara Sinking Truck @ Launchramp
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by Greeko View PostHow did he get that far in....?!?!
Another possibility is that he backed in far enough that the boat's buoyancy floated the rear end of his truck. If he's only 2WD, he's toast at that point. He can (maybe) use his brakes to prevent further immersion, but the truck can't pull itself out. Only hope is to QUICKLY back off the trailer's bow winch and lower the trailer and truck back down onto the ramp, but that would require a presence of mind and quick thinking that are probably absent given the fact that he would get into that situation in the first place. Remember, the truck's parking brakes are useless when the rear tires are floating, so the truck driver would have to stay in the truck while some other person operates the trailer winch.
I guess another option would be to fire up the boat engine and try to drive the boat, trailer, and truck forward enough that the truck's rear tires re-engage the ramp. Again, that would require some deft coordination between the truck and boat drivers, since the former would have to let off the truck brakes when the latter starts driving forward.
Sucky situation to be in, but I'd love to be in the audience with a camera.
It looks you are right in your second thought. Here is more footage and explanation.
http://www.keyt.com/news/boating-mis...r-too/33348950Mike Allen, Tigé owner since 1997
Originally posted by Stingreye View PostFor some reason i found the wind shield wipers being on pretty funny.
Sent from my iPhone using TapatalkMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I've seen something similar happen. The picture below is at Moses Lake in WA and the ramp is very slippery when wet, like some kind of algae growth that gets extremely slimy when wet. If you look at the ramp in the picture, it gets steeper as it gets closer to the water. This guy was driving a 2wd dually and had just put his boat in the water. It floated off the trailer well and his wife was holding onto the boat with the bow line. As the husband was pulling the truck and empty trailer out of the water the wife yelled at him to help her tie the boat to the dock. He stopped the truck 1/2 way up the ramp, put it in park and when he stepped out of the truck onto the ramp it all started to slip back into the water. It was in park with the brake on and it just slid. He jumped into the truck and put it in gear and tried to get up the ramp but he had zero traction. With the weight lifted from the rear of the truck the nice dually wheel setup distributed the weight and gave him zero traction. On this particular day I used the other ramp, which is a little less steep and a little less slick and I also had 4wd from my 4Runner. These are two reasons why I would never buy a tow vehicle without 4wd.
Tigé Jedi
- Jul 2010
- 4303
- TN USA
