I want to put a on board charger in my new Z3. Was curious to know where they put it from the factory?
where does tige mount the on board chargers?
Not a factory option that im aware of, but close to the battery is best. The back side of the rear locker wall is a good spot.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Tigé Junkie- May 2013
- 920
- Central MN
Unfortunatly, our boat is in storage for the winter, so I cannot take a pic. We have the onboard charger from Tige in our 2013 Z1. The charger is mounted port side, rear locker. There is a swivel, that allows a panel to be removed on the back of the portside storage area. The charger is mounted on this panel and the plug in is inside the storage compartment near the top.
I wish I could get you pics. It is a nice location for it."I think I am pretty smart for an idiot"
As stated above it is in the port locker behind the access panel. Mine has a female 3 prong receptical with a flip down cover that you plug into in the port locker so all you do is plug in an extension cord and walk away. It is a great option. I do not have pictures as mine is in storage as well.A man can only be beaten 2 ways - give up or die!
I mounted mine behind the rear locker wall just in front of the batteries. The plug is tucked up near the ballast hoses in the upper right corner of the rear locker wall. The first picture is the first place I mounted it, behind the starboard locker panel, but only because I didn't think it would fit in front of the batteries on the port side. I have since moved it to the port panel where there is enough room to mount it in front of the batteries. In the second picture you can see the back of the bolts that mount the charger to the panel.
