What do you think about Tigé and Indmar teaming up in 2014?
Tigé and Indmar team up for 2014!
Indmar engine built solely for Tige
Without knowing anything about this engine built just for Tige ... booooo I have never been on a Bu/Indmar that was quieter than our Tige with PCM.Last edited by Duncan; 06-14-2013, 01:48 AM.
Correct I think it is a great choice! I was not impressed by the PCM motors... They were a upgrade from the GM Vortecs but they definitely had their fair share of problems in my opinion. Just keep your eyes open and trust me when I say they won't let you down the motor built just for Tige don't let it worry you it won't disappoint.
So what separates Tige from the others now?? How can they have an engine solely developed for them. IMHO, arnt all the engines a 350 chev base, and they put their own spin on them with cranks, heads and manifolds? It maybe pushed towards the wake surfing era more with lower revs, high torque, low fuel consumption.Every Day POETS day - Piss Off Early, Today we Ski
As said on here they are all chevy based engines only marinazation differences, performance should remain about the same because you only can make so much torque and HP from the same base, as far as dependability its all about how you service your engine theres no particular problems with anybodys brand, some maybe more difficult in certain areas to work on but not much.
When we started with Tige you had a choice of Mercruiser, Marine power, or PCM .
Originally posted by lalijaca View PostSo what separates Tige from the others now?? How can they have an engine solely developed for them. IMHO, arnt all the engines a 350 chev base, and they put their own spin on them with cranks, heads and manifolds? It maybe pushed towards the wake surfing era more with lower revs, high torque, low fuel consumption.Originally posted by dom w. forte View PostAs said on here they are all chevy based engines only marinazation differences, performance should remain about the same because you only can make so much torque and HP from the same base, as far as dependability its all about how you service your engine theres no particular problems with anybodys brand, some maybe more difficult in certain areas to work on but not much.
All GM blocks. All it means for certain is the price of the 2014 tige will be alot more.
Originally posted by Duncan View PostIndmar engine built solely for Tige
Without knowing anything about this engine built just for Tige ... booooo I have never been on a Bu/Indmar that was quieter than our Tige with PCM.2011 Tigé RZ4
www.re-viveupholstery.com
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Anyone know what transmission and v-drive Tige will be using with these engines? Does Indmar make their own, like PCM does? Or will it be a third party like Borg-Warner? The engine is only part of the drivetrain, and not always the most likely to have problems... I've already had my transmission swapped out under warranty while my engine just keeps purring along.
Also: I hope Indmar is forthcoming with CAN network codes for their engine parameters, so those wishing to tie in can obtain useful data... just sayin' out loud in case anyone is paying attention....
Indmar uses mefi like everyone else, and their maps are proprietary like everyone else's.
On malibus I think they use a ZF integrated tranny/vdrive unit (ski vee)? Definitely not made in house like pcm.
Having had indmar's 5.7 on my last boat and pcm's on my current one, they are pretty comparable.
Indmar is a little easier to winterize (exhaust manifolds on xover hose) and the raw water impeller is a little harder to change than pcm. Neither is a big deal. I do like that big old fcc fuel filter than pcm uses and the remote oil filter mount.
Some indmar's have the remote oil filter, but not sure whether it's standard now?
