Does anyone have the skylon fatboys 580lbs, locker sacks 600lbs or SL Lunch 440lbs sacks in their 24v? I want to know what you think of each of these and if the fit in the back lockers. I don’t know witch one I should get.
Witch ballast sack should I get in my 24v?
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert EinsteinTags: None
Wake Havasu -
Tigé Jedi- Feb 2004
- 5553
- St. George, Utah
I put the sacs in the lockers, they wouldn't fit under the seats.
Now my 'surfsac' is different. I have a custom sack that runs the entire length of the port side from the back up front to the cooler, with the rear portion 24 inches deep and the under seat portion about 12 inches deep. My best calculations seem to say it gives me about 1350 pounds of ballast. The custom built sack was a pretty penny, but worth it to me.
I use the Tsunami pump. I am toying with the idea of putting in an automated ballast system and am sold on the Rival system as the best for my needs. I just have to have it pass the office of budgetary support (wife).Be excellent to one another.
Supreme Tigé Master
- Sep 2005
- 9278
- 2005 24v
Will the Pro X Series Tube Sac fit under my seats??? Dimensions: 10 in. x 16 in. x 62 in. My boat is at the river in storage so I can’t see it. Anyone know if this will fit.Put your hand on a hot stove for a minute, and it seems like an hour. Sit with a pretty girl for an hour, and it seems like a minute. THAT'S relativity. Albert Einstein
Wake Havasu -
Wake Havasu
Never mind!
I found they do not require an adapter to fit Pro X bags
One Tsunami pump will empty one of the Pro X side sacs in less than 2 1/2 minutes!
