Originally posted by dogbert
View Post
Questions on general inboard boat design...
Originally posted by Guapo View PostThe MC X-35 is self bailing (spelling?). Before I bought my RZ2 last year, I looked at the X-35 and liked that feature. Not sure what method it uses, but there's one wake board boat that has it.the Saltwater X-35 is designed to put you in the spotlight with an array of other impressive features and amenities that definitely help you rise above it all. Such as a smoother ride from the X-35's deeper, self-bailing hullMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by embo View PostOk guys...somehow I am missing how the "submarine" boat does what it does. It appears to just hit a low spot in the water and then the bow dives...what is actually happening there? ?
Love the vid by the way!2009 RZ2, PCM 343, MLA Surf Ballast, Premium Sound.
Wow!! I am not sure whether to laugh or just shake my head in amazement if I saw this in person. Interesting way to wash out the inside of the boat.
The turn looks pretty cool. If I tried that move, my steering cable and throttle would break just at the wrong moment and I would be front and center right up next to the camera.
Thanks for telling me how that was done.Last edited by embo; 10-20-2010, 03:31 AM.
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by Ewok View PostSimilar to what the jet boat does when it puts it's reverse scoopers in the water.
On a jetboat, it dives the bow and causes a huge wave to build in front of the boat, which then collapses by gravity. By modulating the throttle, a good driver can keep the wave in front of the boat (very little water in the boat), move forward so that the wave collapses on the passengers in front, or keep the boat moving so that the wave collapses along the length of the boat and drenches everyone.
We call it the "braking maneuver" and it's a favorite when we have new teenagers in the boat. We have them sit in the rear-facing bow seats so they never realize the wave is there until it is too late. The passengers in back get a nice show but stay relatively dry (except for their feet).
By the way, having brakes has saved us a couple of times from idiots in other boats who weren't paying attention. So this "feature" has benefits beyond just being silly.
Tigé Jedi
- Feb 2004
- 5557
- St. George, Utah
Be excellent to one another.
Berkely/Dominator/Jaquzzi jet systems are not hydrodynamically efficient at lower rpms(approx 1000-2800 depending on vessel displacement). They are directly coupled to the engine so they turn at 1:1 with the motor but are constantly trying to overcome the weight of the vessel as well as avoid cavitation while getting up on plane. Once up to speed and on plane, they become very efficient as the water intake is forced into accepting water through the bottom of the boat.
An example: I built a 1969 19' hallett with a 455 olds (punched out to 468). It would burn 2 gallons an hour at 26 mph turning 2400rpms but at 1900 rpms it was doing 13mph and burning 3 times as much, not quite on plane and sucking down the fuel. And at 4000 rpms, it was doing 63mph and burning 6 gph, nearly the same as cruising.
I'm 6'7" 240lbs and tried wakeboarding behind it once...needless to say, the vessel changed course about 45 degrees and we never tried that again. I'm also a 100ton USCG licensed captain, own several boats, run a commercial towboat for Vessel Assist and my own company, have side-tied hundreds of boats and put them in their slips under tow, and I agree that any single engine inboard is more difficult to manuver than most other vessels if you're not aware of its driving characteristics.
BTW WAboating, I used to own a jet ski rental company and we had 2 of the same "jet" boats that you have. If you have the merc (M2 Jet) power head, a word of warning: Where the power head meets the hull WILL crack and leak, potentially sinking your boat. It happened to some renters in one of ours and the motor actually fell halfway thru the hull. The reason for this is: there is NO stress relief for the thrust of the engine/jet thru the hull. Instead of being transferred through shock absorbing rubber engine mounts into the stringers of the boat, thrust is transferred directly from the vibrating, shaking engine/Jet drive assembly into the NON-REINFORCED 3/16" chip-shot fiberglass motor box surrounding the engine. Older jet boats with big blocks had reinforcement throughout every thrust point area as well as thicker glass and case materials, the boat you have does not.
Inboards: straightforward and reliable service, easy to diagnose, common problems avoidable with proper maintenance, easy parts availability, efficient and proven.
Jets: straighforward and reliable service, easy to diagnose, common problems not avoidable with maintenance, unit needs to be removed for any type of service, no true neutral or reverse, efficient only at and above cruising speeds, proven in commercial craft designed for specific applications.
Note: Cummins/Mercruiser's Zeus Pods...semi efficient but stupid, I could go on for days. Volvo's IPS drives...efficient but stupid, functional for manuverability in tight quarters (i.e. can make even the biggest donkey look like a rockstar when parking at Catalina Island) but still, I could go on for weeks.
And in closing, if you'd like, I would entertain the idea to undertake a design and build effort to produce a running prototype towboat with a jet drive system that followed the same driveline as an inboard "just to see" how it would do.Fixing everyone elses boat just so I can use mine...
Originally posted by talltigeguy View PostThere are 2 ports that are in the main cabin area and they drain downward right to 2 openings just below the swim platform. So any large amounts of water that get into the main cabin area run right down to those openings and back into the lake. I am sure that the cabin area is not waterproof, so I would still expect plenty of water to drip into the bilge from above the storage compartments and such. But it would be super nice for one of those uh, oh, moments when you screw up and take a big roller over the bow. Notice the drains right below the swim platform level. Or it would be very good to have on very high seas when taking some over the bow happens no matter how you drive it. Having been in the X35, I don't think it would be possible to get rollers over the bow except in very rare circumstances. Now my 45 is another story.
Tigé Jedi
- Jul 2010
- 4303
- TN USA
VERY useful info, thanks for sharing!
Originally posted by boatwakes View PostIf you have the merc (M2 Jet) power head, a word of warning: Where the power head meets the hull WILL crack and leak, potentially sinking your boat.
Jets: no true neutral or reverse
Tigé Jedi
- Jul 2010
- 4303
- TN USA
Originally posted by dom w. forte View PostYou didnt comment about the fuel economy?
Many of those factors would be determined by the design goal; you would optimize based upon the nominal operating conditions expected for the watercraft in its intended application. I other words, you'd design differently for a tugboat than for a jetski than for a towboat. (True for open propped versions of those craft, as well.)
