Sea Deck or Similar Fitment Question
    I am looking to replace the carpet in my 2005 24V with a Sea Deck like material. I am hoping someone out there has made a template of the floor area that has been converted to a CAD file of any type (dwg, dxf file) and willing to share the file. I know the floor under the carpet is unfinished and will need leveling. I would also appreciate any guidance for the floor finishing process.
    Gatorstep, seadeck, or ultre deck should already have the file on hand. I sense you are looking to do it yourself tho.. might end up having to trace it out manually.
    Give this a read if you haven’t already. Lots of helpful methods
    https://www.tigeowners.com/forum/gen...-the-ground-up
      I haven't been able to find a company that has the 24V already templated. I'm hoping someone in the Tige collective have done it. I'll check out that thread. Thank you.
        The reason they dont have a template on the website is likely because of the floors needing to be finished and sizes will vary. I would reach out to gatorstep directly.
        Here is a 24v refinished with gatorstep https://www.wakegarage.com/projects-...-refresh-r275/
