I know a bunch of people on here have the rival system with the pro x bags, what is the key to keep them sealed? My front bags leak like crazy when we get up on plane, I am talking half the water comes out of them. We have taken them off and put more tape on the connectors and it still leaks. We took the bags out and tested them for leaks, there are no tears in the bag. The leak comes from the fitting at the discharge pump on the bottom. I thought I heard of someone using rubber cement to fix this but I would like to hear other options. Thanks.
Fix for Leaking Pro X bags in rival system?
Are you sure that the actual bags are leaking? I would be willing to bet money that you are losing water through your fill line due to pressure from the water once you get on plane. I had to install ball valves to keep my bags from draining completely once I got on plane, now they work great.
The only real way to fix this is buying reversible pumps that don't freespin.
Garrett,
How's the old switch V holding up??
There is no way I am losing water thru the fill line, there is a gate valve on the system that closes the thru hull so the fill lines have no where to drain. We also have the check valves on the system. The water was leaking from the connection point on the bag, water ended up just past the bow walkway toward the stern of the boat.
Which connection is leaking? The bag mfgr suggests using PVC cement on the threads screwing into the female fitting on the bag. That makes it very permanent and leak proof. On all other fittings I use some 3M waterproof sealant on all barbed fittings and then clamp them fairly tight too. That front bag is the hardest to seal, but it is possible.
Originally posted by Paublo View PostWhich connection is leaking? The bag mfgr suggests using PVC cement on the threads screwing into the female fitting on the bag. That makes it very permanent and leak proof. On all other fittings I use some 3M waterproof sealant on all barbed fittings and then clamp them fairly tight too. That front bag is the hardest to seal, but it is possible.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
akdoc: Good call on the gate valves. I thought about doing that, I still may in the future.
The Switch is holding up great, just changed the oil yesterday! We've been on the water literally every day this summer, 2-3 sets a day. My brother and I installed some better speakers (polk) around the interior, including 2 up front that we had to cut the glass for (scary, I know...) but it looks sweet. I'll get some pictures for ya. We also put in a new headunit with a digital Ipod hookup, and redid the ballast all around. My brother was pissed he had to leave it behind when he moved to cali, but he's doing work with the Epic guys now, so he's happy.
Tigé Jedi
- Feb 2004
- 5553
- St. George, Utah
Originally posted by da.bell View PostIMO. You will to replace the bag and the pipe with the PVC Cement and only the bag with the Rubber Cement. The cheaper method would to replace the bag only.
I decided that this bag was always going to be used in my boat, and that a permanent attachment in the discharge line was not bad, so I made it permanent. I had some leakage from mine, so I sealed the threads up with some PVC cement, and I do not have any more leakage.Be excellent to one another.
If permanent attachment is okay for you, then use the PVC Cement. It will work very well. I would use the Rubber Cement because I would want a solution other than replacing the bag and the tubing to the bag from the ballast pump. Example if a hole is found in the ballast bag:
PVC Cement: You will need to replace the bag and the tubing from the ballast pump to the bag.
Rubber Cement: You will need to replace the bag only.
The savings is the cost that the tube from your ballast pump to the sac.
Clear as mud?????
Yes, but someone mentioned using PVC Cement and that would glue the male fitting to the bag. But I think I understand what you are saying. I'm just saying that if you use PVC Cement, it is permanent and any thing that you use it on will have to be replaced if the bag were to have a hole in it.
Tigé Jedi
- Feb 2004
- 5553
- St. George, Utah
That makes sense, Mr. Bell.
I have not had any leakage from the quick connect, so I just cemented the quick connects into the bag.
If I cemented everything into the fitting, then I could not remove the bag to let it dry underneath, and that smell would come back.Be excellent to one another.
