Replace serpentine belt
    2019 R23 Raptor 400
    The serpentine belt will not come off due to the water impeller housing and hoses. What is the best way to get the belt off? Remove 3 Allen bolts to pull impeller housing from main crank pulley or remove water hoses from housing? One of the water hoses has a normal hose clamp so should be easy to remove. Other clamp is a single use single ear hose clamp and has to be cut off? What are the cons about removing the impeller housing from main crank pulley ?
    Thanks in advance!!!
