Avx
    Avx
    Should I be able to raise and lower the AVX on the trailer? I went into the surf system in the touch screen and ran the AVX from 0 to 10 and nothing happens. Between buying my rz2 and bringing it home I have seen it act different positions. But now id doesn't seem to be working unless I'm doing something wrong. I just wanted to run it up and down to see how much travel it had and also see if it works. Any tips? Thanks.
    Sent from my LM-V600 using Tapatalk
    You have to get it to move in the dealer menu. There's a demo mode there. It doesn't deploy until you get up to speed via the regular TT menu
    DO NOT switch to surf mode in the menu and do a demo.
      Perfect in got it to go into demo mode. The first time I tried it wasnt doing any thing. Thank you!
        Is 9191 the only dealer code or is there more for other menus?
          9191 is the only one I know for Tige. I know some others for Skiers Choice and Fineline.
            In the dealer menu you need to choose = to surf speed before it will move.
              AVX is a set of CPU instructions developed by Intel (and supported by AMD) smash karts unblocked that allows processors to perform many calculations at the same time using vector (SIMD) operations.
                It sounds like you're having trouble with your AVX system, and that's definitely frustrating. I've heard of similar issues where the AVX seems stuck, almost like trying to get Granny to move on a busy day – sometimes she just won't budge! You might want to check for any loose wires or a blown fuse related to the AVX. Also, ensure the boat's battery is fully charged. Sometimes a low voltage can cause these systems to malfunction. Let us know what you find!
