Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: Marine Power Oil Change questions
  1. #1
    Join Date
    Oct 2003
    Location
    McKinney, TX
    Age
    41
    Posts
    3,053
    Boat
    Previous: 01 23V, 07 RZ2 | 2014 RZ2
    I am about to change the oil in my engine but wanted to verify a few things before I did.
    1. What type of engine oil should I use?
    2. What is the oil filter # or part that I can use?
    3. How much oil should be removed and added?
    I don’t have my manual with me so I thought I would ask here first. I have the Marine Power 360 HT engine. I havent done an oil change in a few years so Im a bit rusty.
    Thanks,
    Matt
  2. #2
    Join Date
    Oct 2003
    Location
    McKinney, TX
    Age
    41
    Posts
    3,053
    Boat
    Well I guess I will answer my own reply since someone else may need this info. This was recommended for my engine type from Andrew Reyes at Tigé
    Oil Weight -5W-30
    Oil Filter - Oreilly Microguard Part# GL20049 Sold at Oreillys
    Oil Amount - 5 1/2 quarts.
  3. #3
    Join Date
    Feb 2004
    Location
    Lake Austin and Lake Buchanan, Texas
    Age
    58
    Posts
    9,511
    Boat
    1999 2100v Limited
    Quote Originally Posted by Matt Garcia View Post
    Oil Weight -5W-30
    That would be good info on the model specs page. Thanks for sharing!
  4. #4
    Join Date
    Jan 2004
    Location
    Mount Juliet, TN
    Posts
    2,621
    Boat
    Tigé
    We use 5 quarts of Penzoil Marine 15w40 and a Penzoil PZ3 filter.
  5. #5
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    50
    Posts
    28,269
    Boat
    I used Mercruiser 15w-40 Marine 4 stroke and an AC Delco PH35 and sucked out about 5 1/2 qts.
  6. #6
    Join Date
    Jun 2006
    Location
    Largo,fl
    Posts
    1,694
    Boat
    03 22v riders edition
    kendall marine grade 15w40 napa 1069 gold oil filter
  7. #7
    Join Date
    May 2006
    Location
    Largo, FL
    Age
    39
    Posts
    1,316
    Boat
    Renegade Nomad 16
    I've been running amsoil 15w-40, but am beginning to wonder if it is worth it. I am about to do my 200 hours oil change and am thinking of going with something else, maybe the Kendall 15w-40.
  8. #8
    Does mercruiser make 15-40 oil? I have only seen 25-40.
  9. #9
    Ask for John
    When in doubt, call Marine Power. Find their phone number here:
    http://www.marinepowerusa.com/
    Ask for John. He knows a great deal and he's helped me out a lot.
  10. #10
    Join Date
    Feb 2004
    Location
    Lubbock, TX
    Age
    66
    Posts
    83
    Boat
    Tige 2100i - 1998
    Matt,
    I have a Marine Power engine in my 98 2100i. I wouldn't argue with Andrew but Marine Power recommended to me to use a straight 30wt. I have the electric pump on mine to pull the oil out of the engine. I generally pull about 3.5 quarts out and I put 4 back in, then just watch the dipstick.
    David
    David
    Lubbock, TX
  11. #11
    Join Date
    Aug 2006
    Location
    Thornton, CO
    Age
    45
    Posts
    11,267
    Boat
    Formerly an '07 RZ2
    Just bumping this back up since people might be changing their oil this time of year.
  12. #12
    What is the best way to drain the oil on an
    MP 5.7L 340hp?
    Unlike my previous I/O it does not have a fitting for the pump out hose.
  13. #13
    Join Date
    Apr 2007
    Location
    Sacramento County, California
    Posts
    20,760
    Boat
    Boatless
    You should have a hose near the starboard side nearest the bow. It will be a rubber hose with a brass fitting on it.
  14. #14
    Join Date
    Jul 2006
    Location
    Sturgis, KY
    Age
    38
    Posts
    7,237
    Boat
    2008 20V
    Mine is on the port side.
  15. #15
    I will need to talk to my dealer since it does not seem to be there. I will see if they used it when they winterized it in the first winter I owned her but did not take possesion until April of 08 and second oil change I had them do for the 20 hour checkup.
    At what they get for winterizing I could heat my garage for the season.
    They are not overcharging because they are in same price range as other in-board dealers to change oil and such but if the hose screws into a brass valve and has enough length to make it out the bilge drain it should be a heck of a lot easier than when I did my I/O.
    I also have a hookup where I can attach a hose into the water intake system just after the weed strainer. I will not need the fake a lake toilet plunger. Basically I isolate the water input from the hull fitting to the hose fitting in the front of the motor by flipping a lever. I will flush this way and then using a Y connector run antifreeze mix into the block. Life's good.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
