Results 1 to 3 of 3
Thread: EIDB replacement
  1. #1
    Join Date
    Apr 2007
    Location
    Mt. Pleasant, SC
    Age
    55
    Posts
    188
    Boat
    '07 22 Ve'
    EIDB replacement
    Good morning all. So while doing some preventive maintenance yesterday on my 2007 22 Ve, I broke off one of the studs on my dual battery isolator. Has anyone replaced theirs with an aftermarket one that they are happy with? I see some affordable ones on Amazon from KeyLine that look like they will do the trick. Thanks for any help or advice!
  2. #2
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    51
    Posts
    28,389
    Boat
    Those diode isolators all pretty much function the same. So the only 2 specs I would look at is A) their intended amperage capacity, which should meet or exceed the alternator's output. and B) stud side to match the cable ends.
  3. #3
    Join Date
    Nov 2018
    Posts
    159
    Boat
    2007 22VE
    I can appreciate a like for like replacement. As an alternative, I’m happy I went the electronic route. It was a little bit of work (some we-working of where battery cables went) but I noticed an immediate improvement in voltage. Kind of one of those things where you don’t see a major change but it gives you a bit of confidence (like corona quarantines)
    Mike has a whole walk through and kit to do it so it’s pretty straight forward IMHO
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
