Page 1 of 2 12 LastLast
Results 1 to 15 of 16
Thread: Boat length and height on trailer HELP....
  1. #1
    I am designing a new garage for my 2013 Z3.
    My boat is in storage no where near home. so I can not go get measurements readily.
    Does anyone know the overall length of a Z3 or probably a R23 on the trailer with the tongue extended and swim platform on?
    What about the height of the tower?
  2. #2
    https://www.tige.com/boats/r23/specs
    This is the 2020 spec sheet with trailer info but it should be very close to your boat.
    10'-3 with tower up and 7'-9 with tower folded.
    Grumble, Grumble
  3. #3
    Join Date
    May 2014
    Location
    Vancouver Island, BC, Canada
    Posts
    1,563
    Boat
    2016 RZX3, 2014 R20 with taps 3
    I’d go for 30’ in length. My rzx3 just fits in a 28’ with platform on tongue slightly folded. And for some reason the rzx3 is shorter than the z3.
  4. #4
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    51
    Posts
    28,324
    Boat
    A 12" door will get you in/out with tower up no clearance issues.
  5. #5
    crapola!!!!
    I am planning on going 36x36 or 40x40 so good there.
    problem is that I can only do 12' walls so that is a 10' door.
  6. #6
    Join Date
    May 2014
    Location
    Posts
    1,563
    Boat
    You might be able to squeeze a 11’ door.
  7. #7
    Join Date
    Nov 2018
    Posts
    128
    Boat
    2007 22VE
    FWIW,
    My 22ve won’t clear a 12’ door with the tower up on the trailer. The damn light catches.. annoying. Maybe it’s the angle of approach or something.
  8. #8
    Join Date
    Mar 2014
    Location
    Abbotsford BC Canada
    Posts
    918
    Boat
    2009 Tige 22ve
    ^^^Whaaaaaat? I have a 22ve and a 10' garage door and I clear with about 6" to spare. How high is your trailer????
    I can't see the older tower being that much higher than the Alpha Z....maybe it is?
  9. #9
    Join Date
    Jul 2012
    Location
    Henderson, NV
    Posts
    959
    Boat
    '14 Z3
    garage at my house is 28ft deep. 8ft door height.
    my z3 fits straight in and tongue folded I have a bit of room to walk around the front to get to the 3rd stall but it's kinda tight. 30ft and you will be good BUT you will have the tongue in the way as you walk around it.
    36 long would be my first choice.
    as to the door 12ft to ensure you don't leave yourself out if you upgrade or trade for a 5thwheel in the future. never measured but I don't think my z3 would fit under a 10ft door as 10ft in most cases is not really a true 10ft after siding and trim.
    kinda sounds like you are going with a kit build so it's a simple flat roof truss? if it's stick framed simply do a 12ft wall and once you are 3ft in on each side bump up the trusses by 2ft to give you the height you need for a 12ft door. 36ft wide and a simple 4/12 roof will allow you plenty of truss space to bump it up. any good truss shop should be able to build that for ya but a 36ft span is going to be a spendy truss. 30ft wide would reduce your costs quite a bit and still as wide as a 3car garage.
    if it is a kit, see if they can build a 12ft wall, flat roof for 3ft on each side then jog up 2ft and finish the rest of the roof.
    pic is extreme but you get the idea...
    good luck.
    2012 22ve.. RIP 4/17
    2014 Z3.. Surf away
  10. #10
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    51
    Posts
    28,324
    Boat
    Quote Originally Posted by MJO21 View Post
    crapola!!!!
    Well, you would just need to let tower down a bit, back in, then you can pop the tower back up.
  11. #11
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    51
    Posts
    28,324
    Boat
    Quote Originally Posted by BCRider View Post
    The E Series is noticeably taller then the Alpha-Z, but dang, Brent's 07 trailer must be on 32's Ive had a half dozen or so 22/24 V/Ve boats in and out of my shop and clearance has never been an issue on my 12" door.
  12. #12
    Join Date
    Nov 2018
    Posts
    128
    Boat
    2007 22VE
    Quote Originally Posted by chpthril View Post
    Yup. I’m hindsight I’m a dirty dirty liar and we have 10ft doors. But I don’t clear them
    Also, maybe I should lift my trailer. Bring out my redneck. Hmmm.....
  13. #13
    Quote Originally Posted by BrentP View Post
    Blang Blang
    Grumble, Grumble
  14. #14
    Join Date
    Nov 2018
    Posts
    128
    Boat
    2007 22VE
    For when you need to take your wake boat all terrain. No boat ramp no problem.
  15. #15
    We launch from the beach, at a couple of our lakes. I’ve soaked my truck carpet a couple of times, I have to back in so far to get my boat in far enough to get off the trailer. I’ll have to buy Gravedigger to launch, if I buy the trailer lift kit.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
