Results 1 to 12 of 12
Thread: DIY-Adding second battery
  1. #1
    Join Date
    Aug 2019
    Location
    WA
    Posts
    16
    Boat
    '19 R22
    I didn't find much info on adding a second house battery for a larger stereo, so i thought this post may help some people.
    To start, the factory battery is a size 24 and doesn't have much capacity for floating and listening to the system. A second battery (or battery bank) allows the start battery to be isolated and not be drained by the amps and offers the ability to still get home even if you drain the second battery. I went with a size 31 AGM for the second house battery.
    I like the Blue sea Systems add a battery kit i used in a previous boat, so decided to use it again with a couple changes.
    https://www.bluesea.com/products/765...ery_Kit_-_120A
    The kit consists of 2 parts, the dual battery switch, and SI ACR that controls charging.
    I followed this diagram for the most part, borrowed from the net:
    I did not place fuses between the ACR since I'm not concerned about a possible short on the short 4ga wires. Also, i only connected the ground wire for the ACR since i do not need the monitor led or starter cut out.
    Here is the starting point on our '19 R22
    Pulling of the engine access panel and unscrewing the rear panel, you'll find the stock switch and single battery
    Working on the bench, i removed the battery switch and enlarged the hole for the blue sea systems dual battery switch. ACR got mounted below the switch. Then i moved over the power plug so i could install the battery charger plug on the starboard side along with mounting the dual bank 20 amp charger from Powermania
    Back in the boat, i moved over the starting battery tray to allow room for the second battery. The start 24 tray will hang off the edge about an inch for enough room to fit the house 31 size. Here is the test fit for the trays and two batteries:
    Then moving on to wiring up the new battery switch, keeping everything on the starting battery and 1 side of the switch that was originally wired, minus the 4 ga yellow and red wires from the factory amp. Connect the amp red power wires to the 2 position of the battery switch and the ground on the house 31 battery. I added a 2 ga ground wire between the two batteries instead of using a seperate ground bar.
    The charger also gets connected to each battery and the ACR ground wire to the start battery with a 2amp fuse (smallest i could find in the mini size)
    Then put it all back together, making sure to reconnect the light and power port. Shown here with the charger plugged in testing connections.
    The charger is accessed by opening the battery door
  2. #2
    Join Date
    Nov 2016
    Location
    Union Michigan
    Posts
    244
    Boat
    2014 RZR
    Looks great! I’ve been thinking of doing the same thing.
  3. #3
    If you want to isolate engine you will have to make this wiring change. This will keep house from pulling from cranking. Your stereo and house can share and be on bank.
    Grumble, Grumble
  4. #4
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    51
    Posts
    28,282
    Boat
    Good catch Koolaid! He will have loads drawing from both banks while at anchor as it stands.
    Also, I hate how that artist poorly labeled the batteries. "house" and "stereo" are redundant. "stereo" IS a house load.
    Sadly, incorrect info, such as this schematic, get on the web, and stays there.
  5. #5
    Join Date
    Nov 2018
    Posts
    118
    Boat
    2007 22VE
    Question though. That change you made will push the main dash panel/helm bus onto the house bank. So the starter is on its own battery, but all the electronics are not? Or does the engine ECm, fuel pump, etc all connect to the starter?
    I actually kept my main helm bus on the starter battery for this reason. The major down side is all my ballast pumps run off that battery (since they are factory wired into the helm bus). I figure in the grand scheme of things, if one of those gets left on i probably have enough juice in the house batteries to combine and jump the motor. Long term I’d have to basically install a second helm bus for “house” loads, and keep the existing one for critical operation electronics right?
  6. #6
    Quote Originally Posted by BrentP View Post
    That change you made will push the main dash panel/helm bus onto the house bank. So the starter is on its own battery, but all the electronics are not? - Exactly. This is what you want it to be. That way you always have a charged engine battery. The ECM, fuel pump (the engine fuse panel actually) gets power from the starter wire. The alternator feeds power to the starter wire as well.
    How you set up your boat isn't the ideal method. You never want to pull power from cranking battery unless you are cranking. If you have house items on the cranking battery, the isolator can go haywire switching back and forth trying to keep cranking topped off or it will never see full charge on the cranking battery which causes it to never charge the house battery. See 2015-2016 boats with the pro mariner and incorrect wiring from starter to alternator.
    Grumble, Grumble
  7. #7
    Join Date
    Jul 2012
    Location
    Henderson, NV
    Posts
    949
    Boat
    '14 Z3
    Quote Originally Posted by KoolAid View Post
    wait...
    I have a'14 with the factory promariner. is this something I need to look for? I doubt my boat has spent much time at a dealer over the years on recalls and such.
    2012 22ve.. RIP 4/17
    2014 Z3.. Surf away
  8. #8
    '14 didn't have the issue. The early raptors did. The alternator wire was cut at the factory and a new wire was ran directly to the promariner which caused the engine to always pull from cranking battery which would make it fall below the threshold of 12.3v (IIRC).
    Grumble, Grumble
  9. #9
    Join Date
    Aug 2019
    Location
    WA
    Posts
    16
    Boat
    '19 R22
    Thanks for the input KoolAid. I followed the Blue Sea System diagram that had the "start" side keeping all electronics, but had accessories on the house side. I wasn't sure where the ECM draws power from and wanted to keep it on the start battery.
    The other item i need to find out is how the Touch 2 monitors voltage. It has dual readings for start and house, both currently have the identical reading, I assume from the same source.
  10. #10
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    51
    Posts
    28,282
    Boat
    This is part of what Koolaid has pointed out. In your original schematic, the helm and (which should draw from the house) is connected to the main cranking. So yes, they would "see" the same battery voltage.
  11. #11
    Join Date
    Aug 2019
    Location
    WA
    Posts
    16
    Boat
    '19 R22
    Quote Originally Posted by chpthril View Post
    Perfect, I was hoping that would solve the issue.
  12. #12
    Cranking voltage on the screen is from the ECM through CAN. House voltage is what the screen itself is seeing. Mike answered the rest :-)
    Grumble, Grumble
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
