Results 1 to 2 of 2
Thread: 2005 Tige transmission problem
  1. 2005 Tige transmission problem
    Problem with 2005 Tige direct velvet drive...Does not engage the propeller in forward or reverse..Any ideas???
  2. #2
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    50
    Posts
    28,219
    Boat
    Fluid level first. Then check to make sure cable is moving the shift lever. Third, when engaged, look to see if the output flange is spinning or not.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
