Page 1 of 2 12 LastLast
Results 1 to 15 of 21
Thread: Raptor 440 drain plugs
  1. #1
    Join Date
    Feb 2019
    Location
    WI
    Posts
    30
    Boat
    2019 ZX1
    Hi All - Planning to winterize my ZX1 soon.. Trying to figure out where everything is so I can be ready when the time comes..
    So far I've been able to find 4 of the 5 drain locations. I've been able to find all of the locations on this first image:
    - Transmission Drain/Anode Blue Plug
    - Transmission Cooler Drain Blue Plug
    - Heat Exchanger Drain Blue Plug
    - Pump Impeller Housing
    I can't for the life of me find the "blue plug of separate fitting on exhaust manifold crossover hose"
    Any other ZX1 or Raptor 440 owners out there struggling with this? Or am I looking for something that is not there.. I've seen some posts in other forums where people suggest that the exhaust manifolds on some of the newer raptors do not need to drain this as it drains on it's own through the other plug locations.. Definitely do not want to risk any issues here though.
    Thanks!
  2. #2
    Join Date
    May 2014
    Location
    Vancouver Island, BC, Canada
    Posts
    1,514
    Boat
    2016 RZX3, 2014 R20 with taps 3
    This should help.
    https://youtu.be/AtHaY4D2YHo
  3. #3
    Join Date
    Feb 2019
    Location
    WI
    Posts
    30
    Boat
    2019 ZX1
    Thanks Reid- I’ve watched that vid a couple times, but I literally do not have a hose like that anywhere visible above or below the vdrive.
    In the vid, after he pulls the vdrive plug he works on the plug in the hose I can’t find. The hose is literally right near the vdrive. That is the same way it is displayed on the user manual images.
    I can’t find anything like that above or below my vdrive.
  4. #4
    Join Date
    Aug 2015
    Location
    Salt Lake City, Utah
    Posts
    1,701
    Boat
    2017 RZX3, 2013 MB F24, 2000 21V
    As I recall, I dont have that cross over line either. On each exhaust manifold towards the rear of the engine I have a large metal plug. I believe these are the “separate plugs” the text is referring to. I just remove them and allow the water to pore out. Not sure why some engines got the cross over and some didn’t.
  5. #5
    Join Date
    May 2012
    Location
    San Angelo, TX
    Posts
    860
    Boat
    2015 Z3 w/AVX
    I believe you are missing the exhaust riser drains as well. As Unstuck mentioned, some models have drain plugs in the risers instead of a hose connecting the two as mentioned in the manual.
    It will either be a blue plug or a brass fitting itself on each riser.
  6. #6
    Join Date
    Feb 2019
    Location
    WI
    Posts
    30
    Boat
    2019 ZX1
    Quote Originally Posted by UNSTUCK View Post
    Thank you! I did notice what felt like a bolt on the back of each manifold, but figured it was wrong. I’ll take a closer look but this makes sense!
  7. #7
    Join Date
    Jul 2015
    Location
    Orange County
    Posts
    1,877
    Boat
    Tige, Sc, Atx, Avalon, Quest
    Quote Originally Posted by Skidude04 View Post
    The 400/440 will have the following..
    Blue plug- Exchanger
    Blue Plug-Bottom of V drive
    Blue Plug-At the crossover pipe next to the exchanger
    Brass manifold drain plugs at the back of each manifold (opposite side as the belts)
    The 400/440 will not have a cross over manifold hose as Tige does not do this with any models.
    The 400/440 will also not have a v drive cooler hose underneath the motor.
    The 460/575 will have all of the items above plus a little black drain screw as well as a trans cooler line that will receive a blue freeze plug as well. This hose is often hard to see, it usually is best located directly under the motor next to the oil pan. It will have a brass female fitting on the end which accepts the blue plastic freeze plug.
    Germaine Marine
  8. #8
    Join Date
    Jul 2015
    Location
    Orange County
    Posts
    1,877
    Boat
    Thanks!
    The photos you are looking at are for the 460 which is not your engine. Look at the 400/440 diagram. The 400 is the same motor hard part for hard part.
    Germaine Marine
  9. #9
    Join Date
    Jul 2015
    Location
    Orange County
    Posts
    1,877
    Boat
    This last photo is a pic showing a 2 into 1 cross over hose from each manifold. Tige does not use this setup. Instead you will have a big bass drain plug at the rear of the motor on each manifold. Remember the motors are actually sat in the boat backwards with the front of the motor facing toward the rear.
    Germaine Marine
  10. #10
    Join Date
    Feb 2019
    Location
    WI
    Posts
    30
    Boat
    2019 ZX1
    Quote Originally Posted by Germaine Marine View Post
    THANK YOU!!!
  11. Any reason for Tige not to include the cross over manifold hose? Seems to be a much easier way to drain the manifolds.
  12. #12
    Quote Originally Posted by cramer View Post
    Some models will not clear the floor/liner so they use the two brass plugs.
    Grumble, Grumble
  13. #13
    Join Date
    May 2012
    Location
    San Angelo, TX
    Posts
    860
    Boat
    2015 Z3 w/AVX
    Quote Originally Posted by KoolAid View Post
    I haven't seen any cross over hoses on any particular model that I can recall lately, but in 2015 I know the 400 Z3 did have the hose.
    @KoolAid, is there any models now that have the cross over hose?
  14. #14
    Quote Originally Posted by jslayde1 View Post
    I haven't seen any cross over hoses on any particular model that I can recall lately, but in 2015 I know the 400 did have the hose.
    R series for 2020, non 360 models.
    Grumble, Grumble
  15. #15
    Join Date
    May 2012
    Location
    San Angelo, TX
    Posts
    860
    Boat
    2015 Z3 w/AVX
    Got it!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
