Results 1 to 5 of 5
Thread: Bennett Taps Actuator
  1. #1
    Join Date
    Nov 2016
    Location
    Union Michigan
    Posts
    232
    Boat
    2014 RZR
    I have a bad taps actuator sending unit. How does the wiring disconnect for removal?
  2. #2
    Back up here. Are you sure the sending unit on the actuator is bad and not the taps module under the dash?
    You should have 240ohms across both green wires. If you get 240, actuator is good and the taps module is bad.
    Grumble, Grumble
  3. #3
    Join Date
    Nov 2016
    Location
    Union Michigan
    Posts
    232
    Boat
    2014 RZR
    I have an open circuit.
  4. #4
    To answer your main question, you cut the green wire near the transom and splice into it with the new actuator. Go ahead and cut it first. Then do an ohm reading there to validate the actuator is bad. You may get lucky and just have a bad connection along the path. The wires (in one green casing) run down the starboard side of the boat to the dash harness.
    Grumble, Grumble
  5. #5
    Join Date
    Nov 2016
    Location
    Union Michigan
    Posts
    232
    Boat
    2014 RZR
    Thank you
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
