Results 1 to 2 of 2
Thread: 2010 24ve PCM 343 motor Starter Fuse
  1. #1
    The starter fuse in my 24ve keeps blowing when I try to start the boat. I have tried replacing the relay also but had the same result. Any help appreciated
  2. #2
    Does it blow with the relay unplugged? If so you have a short on the harness. I assume you are meaning the fuse on the yellow/red wire at the ignition key.
    Grumble, Grumble
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
