Page 1 of 2 12 LastLast
Results 1 to 15 of 26
Thread: Taps T3 upgrade
  1. Taps T3 upgrade
    Does anyone know much about Taps T3? what are the biggest differences? would you be able to get e T3 system installed on a 2019? is the only difference the actual plates and their shape or is there more mechanical differences that would make it hard to upgrade to them?
  2. #2
    Completely different actuators along with software to run the system.
  3. #3
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    51
    Posts
    28,353
    Boat
    GSA plates now, on the 2020 "GO" system, v's Tige's plates.
  4. #4
    Join Date
    Aug 2015
    Location
    Salt Lake City, Utah
    Posts
    1,736
    Boat
    2017 RZX3, 2013 MB F24, 2000 21V
    It's becoming common for guys to swap over to the GSA plates and continue to use the TAPS3 actuators and control.
  5. #5
    The plates are 1500 and you need to uninstall taps original plates and instal the gsa tabs.
    I’d like to try it but the idea of drilling holes in my boat isn’t something I’m prepared to do.
  6. #6
    Join Date
    Sep 2008
    Location
    Helena,MT.
    Posts
    1,057
    Boat
    2019 zx5 fully tricked
    I’ve done my last few boats with gsa and it’s well worth the change trust me I spend tons of time fine tuning and dialing stuff in.
    surf till u die.
  7. #7
    Join Date
    Jul 2010
    Posts
    240
    Boat
    2018 r23
    Quote Originally Posted by Surf406 View Post
    @Surf406 - so you are using same actuators and TT2 system when you do this (ie changing plates only?)
    I am thinking of doing this on my taps3 2018 R23 but have the smaller tt2 screen. I can dial in the wave fine and with big weight it's great once dialed, but because of the way ballast has to be set up now for goofy (lots more to surf side), it makes transfers not possible (dirty backside wave...).
    im hoping with gsa plates i can weight the boat more evenly again to take advantage of the great surf hull and weight and full transfer capabilities. also, making wave less "sensitive" if that makes sense. would you say this plate swap to gsa-style accomplishes that?
    tia
    cnote
  8. #8
    Join Date
    Sep 2008
    Location
    Helena,MT.
    Posts
    1,057
    Boat
    Dm me and I’ll get you my phone number
    surf till u die.
  9. #9
    Join Date
    Jan 2018
    Location
    Boise, ID
    Posts
    109
    Boat
    2018 R23, Centurion Avalanche (previous)
    I've been thinking of dong this also on my '18 R23. I've been told I can use the actuators from my taps3 however the mounting location of them would have to change meaning there would be fiberglass work involved and drilling new holes. Still trying to decide if it is worth it. Hummmmm??
  10. #10
    Join Date
    Oct 2010
    Location
    Murrieta, CA
    Age
    51
    Posts
    1,122
    Boat
    Previously 2004 22i, 2014 Z1, now 2015 Z3 with GSA
    Quote Originally Posted by Sublimer23 View Post
    It's worth it!
  11. #11
    Join Date
    Aug 2015
    Location
    Posts
    1,736
    Boat
    Instead of doing the fiberglass work, I built a cover plate the same shape as the actuator mount. I then sealed it and screwed it to the transom using the original screw holes. This made it possible to return to stock if I ever need to. I used polished SS, so it stands out against my black gel coat. I could have easily painted it black and no one would ever know it's there.
  12. #12
    Join Date
    Jan 2018
    Location
    Boise, ID
    Posts
    109
    Boat
    Quote Originally Posted by D&P Powell View Post
    It's worth it!
    I'm happy with the wave as it is. However hauling around 600 lbs lead in the rear makes the boat tow terrible. Bouncy and tail happy. It would be nice to have the same wave and not haul around that lead.
  13. #13
    Join Date
    Jan 2018
    Location
    Boise, ID
    Posts
    109
    Boat
    Quote Originally Posted by UNSTUCK View Post
    That's a great idea! Having the option to return to stock would be nice too.
  14. #14
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    51
    Posts
    28,353
    Boat
    Are you running aftermarket rectangle PnP sacs in the back locker?
  15. was really hoping that i could just swap out the tabs at the hinge point, and hook them right up to the stock actuators. no need for any fiberglass anything. that would be too easy i guess lol
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
