Results 1 to 15 of 15
Thread: tower rattle
  1. #1
    Join Date
    Jul 2010
    Posts
    240
    Boat
    2018 r23
    tower rattle
    2018 R23, manual tower (M2). past weekend tower started to make a rattling noise when going over light chop. Isolated to tower base on starboard side. dropped the tower to look, bolts are all tight. there is some sort of what appears to be a brass spacer or bushing, not sure if that's it, but as i said everything seems tight.
    anyone have any experience with this? resolution?
    TIA!
  2. #2
    Join Date
    Oct 2018
    Location
    Parker, TX
    Posts
    373
    Boat
    Tige R23
    Yes. I have same issue. Sounds like metal to metal slapping together very hard. I also isolated to the starboard base. The tower slides side to side in the base. No known solution. Dealer checked it and said tower is good. It sounds like absolute crap!!!! Embarrassing!
  3. #3
    Join Date
    Oct 2018
    Location
    Parker, TX
    Posts
    373
    Boat
    Tige R23
    Here’s a thread I started sometime back.
    Alpha M2 Tower Noise
    https://r.tapatalk.com/shareLink?sha...2&share_type=t
  4. #4
    Join Date
    Jul 2010
    Posts
    240
    Boat
    2018 r23
    ugh.. well that sucks. not cool, and not ok. rattle leads to break. no joy on the plastic bushing?
  5. #5
    Join Date
    Oct 2018
    Location
    Parker, TX
    Posts
    373
    Boat
    Tige R23
    I haven’t folded it down yet to look. I was spending extra boat time messing with leaking ballast. I’ll take a look when I winterize it
  6. #6
    Join Date
    Aug 2015
    Location
    Salt Lake City, Utah
    Posts
    1,736
    Boat
    2017 RZX3, 2013 MB F24, 2000 21V
    My power tower does the same thing, in the same place. Actually, it did it for a while and then stopped but has started doing it again the last month. I thought the first time it happened was because the tower was not fully seated in the upright position so I lowered it a bit and then raised it again. No change. I have recently been putting the tower down while traveling. About the same time the noise came back the second time. I wonder if this is the cause. Do you guys tow with the tower down or do you leave it up?
  7. #7
    Join Date
    Oct 2018
    Location
    Parker, TX
    Posts
    373
    Boat
    Tige R23
    Mine is not the E2, so it is not powered. You can only tow with the powered towered down. So no, always tow my boat with tower up.
  8. #8
    Join Date
    Jul 2010
    Posts
    240
    Boat
    2018 r23
    ive never had the tower down since i got the boat last year, until last week when trying to troubleshoot the noise.
  9. #9
    Join Date
    Jul 2015
    Location
    Orange County
    Posts
    1,897
    Boat
    Tige, Sc, Atx, Avalon, Quest
    Quote Originally Posted by Bamer View Post
    You can tow with the power tower up or down.
    Germaine Marine
  10. #10
    Join Date
    Oct 2018
    Location
    Parker, TX
    Posts
    373
    Boat
    Tige R23
    tower rattle
    Quote Originally Posted by Germaine Marine View Post
    I meant you cannot tow with the unpowered tower down. Powered tower can be towed up or down. Sorry for the confusion.
    Any thoughts about the rattle?
  11. #11
    Join Date
    Jul 2015
    Location
    Orange County
    Posts
    1,897
    Boat
    All good home slice. We are working on a pin setup for you all for the M2 to allow it to be towed tower down. Ill update you all when its done. I believe the coverall cover will also work with this once finished.
    Germaine Marine
  12. #12
    Not the most elegant solution, but if the issue is is sliding back and forth is the mounting base just make a piece of rubber that will shove into that gap and hold it in place.
  13. #13
    Odd. Let me look into this.
    Grumble, Grumble
  14. #14
    Join Date
    Oct 2018
    Location
    Parker, TX
    Posts
    373
    Boat
    Tige R23
    Quote Originally Posted by SONIC View Post
    Assuming all shims/bushings/washers or whatever are installed correctly (my dealer said it is) and are not damaged, I am pondering adding a rubber material to prevent the movement.
    Hopefully someone associated with Tige can provide some insight.
  15. #15
    It will need to be something like delrin. Rubber or something like that is too soft. You want something that will not compress and will not squeak.
    Grumble, Grumble
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
