Page 1 of 4 1234 LastLast
Results 1 to 15 of 54
Thread: Kyle's 24V Stereo Upgrade
  1. #1
    Join Date
    Aug 2015
    Location
    Riverside, CA
    Posts
    188
    Boat
    2005 Tige 24V RE
    This winter my next project is to tackle the boat stereo. My goal is to do the install myself, rely as much as possible on open box/refurbished gear to save money, add bass, and swap out most of the non-marine gear with actual marine components. I will post pictures and progress as I go but figured I would start the thread today! Wish me luck!
    Old Gear:
    1) Four 6.5” Alpine Type R component speakers with Tweeters (two in bow, two at stern, 4 ohms resistance each)
    2) Two sets of Diamond Audio tower speakers. These are the 6.5” + 5” + tweeter all wired together to one output. At least one speaker in each enclosure is blown.
    3) Alpine head unit
    4) Alpine MRV F 545 4 channel amp. Solid amp @ 125Wx4 RMS @ 4 ohms
    My Plan:
    1) Keep head unit and add WS-420 to have zone control and PA function
    2) Add 12 “ FA subwoofer installed under the helm. I am thinking of buying a WS Revo 12 FA 2 ohm “Amazon Renewed” unit. Seems like a killer deal!
    3) Add Exile Audio Javelin 5 channel amplifier (already have amp from another project)
    4) Add an additional set of in boat speakers. I am thinking a pair of 6x9’s to have some speaker variety in boat. So I will have four 6.5 inch speakers and two 6x9 speakers.
    5) My plan is to wire up ch 1 & 2 to one speaker each and then 3 and 4 powering two speakers each wired parallel. Channel 5 is a dedicated sub channel. So the Javelin amp will power 6 speakers and the subwoofer. Ch 1 and 2 will be 4 ohms and 3, 4, and sub will be 2 ohms (3 & 4 = each powering two 4 ohm speakers wired parallel, 4 divided by 2?) Ch 5 can handle up to 800w RMS @ 2ohms. Does this make since? Is that the correct final resistance load for channels 3 & 4?
    6) Eventually I will swap out Alpine type R car speakers for marine speakers. I am thinking Polk DB65s since they are the only marine component speakers I can find. But the Alpine speakers are very good speakers from what I can tell.
    7) Keep Alpine 4 channel amp to power tower speakers
    8) Swap out old and blown out Diamond Audio tower speakers for a pair of Rockville Audio DWB80’s (four 8 inch speakers total). I know Rockville isn’t the best quality but they are within my budget and I have heard good things considering the cost. Each 8 inch speaker will be powered by one channel from the alpine amplifier. I am thinking these will still be a nice upgrade from the diamond audio set up.
  2. #2
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    51
    Posts
    28,280
    Boat
    I would seriously consider going with the Kicker KM8 over those shared-tooling rockville branded pods. I guarantee the KM8 is a 10X better sounding and better built speaker.
    What is "amazon renewed"? Whos the actual vendor?
    Why 6x9 v's round 8"? The 8" round has more surface area as well as we can get more excursion out of the round speaker.
  3. #3
    Join Date
    Aug 2015
    Location
    Riverside, CA
    Posts
    188
    Boat
    2005 Tige 24V RE
    Quote Originally Posted by chpthril View Post
    I looked at the KM8's but from what I can tell the enclosure has the traditional tower clamp mount for tubular towers. I have the old Phat Buddy tower that has a flat plate mounted on top at the two parallel cross bars. The Rockville's are the only ones I have found where the roll bar clamp can be removed so it can be mounted on a flat surface.
    The vendor is Amazon. Here is the link. https://smile.amazon.com/dp/B07N8HVR...v_ov_lig_dp_it
    https://smile.amazon.com/dp/B07N8JFB...v_ov_lig_dp_it
    good question hahahah just spit balling. I will look into in boat 8" speakers.
  4. #4
    Join Date
    Sep 2012
    Location
    La Verne, CA
    Age
    41
    Posts
    1,094
    Boat
    2004 24V Riders Edition PCM ZR6 6L
    I have two pairs of 8" Kickers and love them. I upgraded from the KMT67's which were good but I really like the 8" kickers. Not sure on the price difference but if you can figure out how to mount them, I really like them.The clamp on the enclosure does come off and is flat I think but you would need to talk to a guru like MLA / Mike to know if you could bolt that to the flat plate instead of the tube mount clam that are on the 8" kicker cans.
  5. #5
    Join Date
    Sep 2012
    Location
    La Verne, CA
    Age
    41
    Posts
    1,094
    Boat
    interesting, the have changed the enclosures since I did mine.
    THere are these which are new:
    https://www.kicker.com/kmfc-8-inch-coaxial-tower-system
    and these which were what was available when I did mine:
    https://www.kicker.com/43KMTES8B
  6. #6
    Join Date
    Jul 2012
    Location
    Henderson, NV
    Posts
    948
    Boat
    '14 Z3
    sounds like a fun winter project and I would follow mla's advice-especially on the tower units. he knows his shiot...
    my .02 fwiw,
    if you are going to all the work, build an enclosure for a sub. personally think they sound better. it doesn't cost a ton to build a box.
    polk db's are great boat speakers. had 6 of them in my first supra and they were very nice. you will not be disappointed with them.
    I saw 6x9's and my mind immediately went to images of an old 60's/70's muscle car with a set of triaxles on the back package shelf I'd keep all the in boats from the same speaker line if it was my $$.
    mla might be able to hook ya up with a package deal on tower and in-boats. spend some coin there as old rule of thumb was to buy speakers first in any install as most tend to buy other stuff first and skimp on speakers. that will make or break your sound quality.
    2012 22ve.. RIP 4/17
    2014 Z3.. Surf away
  7. #7
    Join Date
    Nov 2018
    Posts
    115
    Boat
    2007 22VE
    Sandm is on point. I wasn’t going to replace speakers and then I sat down and really listened to my 10 year old in boats and realized I was an idiot. I couldn’t be happier I replaced them
    Good clean power, good speakers go a long way.
    Have you considered some kind of custom mount for the tower speakers vs limiting yourself to a specific (low end) option?
    Good luck and keep us up to date!
  8. #8
    Join Date
    Aug 2015
    Location
    Riverside, CA
    Posts
    188
    Boat
    2005 Tige 24V RE
    Quote Originally Posted by Stingreye View Post
    Thank you for the feedback. I am going to probably hold off on tower speakers until I can find a suitable mounting position. I will post some photos of my delimia shortly. Perhaps you or Mike may have an idea on a solution.
  9. #9
    Join Date
    Aug 2015
    Location
    Riverside, CA
    Posts
    188
    Boat
    2005 Tige 24V RE
    Quote Originally Posted by sandm View Post
    my .02 fwiw,
    Thank you for the advice!
  10. #10
    Join Date
    Aug 2015
    Location
    Riverside, CA
    Posts
    188
    Boat
    2005 Tige 24V RE
    Here are some photos of my tower. As you can see there are spots where a flat piece of metal is welded to the 2.5" tube and then the speaker pods are mounted directly to this. Do you think I can break these welds in clean way and remove the flat piece so I can use typical tower clamps mounts for speakers or can most pods detach from the clamps to mount to a flat surface? Thanks for any input!
  11. #11
    Join Date
    Sep 2012
    Location
    La Verne, CA
    Age
    41
    Posts
    1,094
    Boat
    These are the enclosures I used with kicker km8’s
    https://www.kicker.com/app/manuals/m...MTES_Rev_C.pdf
    You can see how the clamp attaches in the pdf, I am not sure if that can mount directly or not but it is flat there. I am not sure if you would have clearance or need a spacer or anything.
    I would be a little afraid of removing flat piece if it was providing any support for the tower. If it was just for mounting the speakers then maybe you would be ok.
  12. #12
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    51
    Posts
    28,280
    Boat
    What the width of the plate?
  13. #13
    Join Date
    Aug 2015
    Location
    Riverside, CA
    Posts
    188
    Boat
    2005 Tige 24V RE
    There is a pate on each top tube (front and back). Each one is 2.5 inches or so wide. I don't think it is there for structure. In fact, I think it might have even been added after the fact to mount the existing speakers. In googling the Phat Budde Extreme Tower I see some pics that do not have these plates. But my concern would be that It wouldn't look clean if I removed. Ideally I would like to find a way to mount pods to the flat plate.
  14. #14
    Join Date
    Jul 2017
    Location
    Nashville
    Posts
    354
    Boat
    2000 21v Riders
    I think you have a few options
    1 you could use the plates drill and tap them I am not sure of the speakers you want to use I know wet sounds swivel clamps have a flat part that would mount flat surface. You would have to fond a way to seal the wires up if you didn't make the connection in the back.
    2 you could cut the flat metal out just big enough to get the clamp around the tube.
    3 cut the flat metal at the weld you can cut it back at some kind of angle so what is left looks like a gusset welded to the tower. then use what ever speakers you prefer. This is what I think I would do.
  15. #15
    Join Date
    Jul 2017
    Location
    Nashville
    Posts
    354
    Boat
    2000 21v Riders
    I do think you are correct. They are there to mount speakers on. They have no structural reason I can see. if you cut them from weld to weld (leave a small triangle) it will look like they are there for bracing/gusset. But to break the weld cleanly would be tough you would need to do some sanding then re-powder coat the tower.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
