Results 1 to 6 of 6
Thread: Batteries dying too often.
  1. Batteries dying too often.
    Need some help trying to power my aftermarket stereo system without killing the batteries so quickly.
    I currently have 2 wet sounds rev 10 tower speakers, 8 6.5 “ Rockford fosgate speakers in the boat, one 10” sub and one 15” in sub. Using 3 amps to power the system.
    I’m also using 2 heavy duty marine master batteries and one deep cycle energizer battery all connected in parallel. It seems like the batteries are dying out way to fast when the boat is off. Even when the stereo is not running at full capacity.
    I heard getting a solar battery charger might be a good option to throw on the batteries while only running the stereo. Also not sure if getting one more battery would help.
    Any thoughts would be appreciated!
  2. #2
    Join Date
    Oct 2018
    Location
    Parker, TX
    Posts
    376
    Boat
    Tige R23
    Quote Originally Posted by ArizonaLaker View Post
    What’s the total wattage of Amps? What class are the Amps? What size alternator do you have? Do you use charger to charge the batteries when not in use(like when in storage). Do you have a separate crank battery or are 3 used for house and crank? How old are the batteries?
  3. #3
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    51
    Posts
    28,357
    Boat
    This is an issue for me. You should have 3 identical batteries and in a perfect world, they should have all be brand new when they went into this configuration.
    Next up, how are you recharging these when you come off the water?
    Voltage? What is the starting and finishing voltage?
  4. #4
    Join Date
    Oct 2018
    Location
    Parker, TX
    Posts
    376
    Boat
    Tige R23
    I’d go with the rule of thumb that any time you have batteries connected in parallel, you should use the the same brand and age like chp said and I’d always keep a charger on them. If the batteries are not evenly balanced well they can discharge each other overall several days, weeks or months depending on the actual batteries.
  5. #5
    Join Date
    Jul 2017
    Location
    Nashville
    Posts
    354
    Boat
    2000 21v Riders
    I do agree with all the above statements. I have done all the above but I also use a solar charger. Since where the boat is stored is outside and there is no available power to plug into.
    sorry thought it might come out upside down. you will have to stand on your head to view.
  6. #6
    How fast is too fast?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
