Results 1 to 4 of 4
Thread: Rudder Rebuild?
  1. #1
    Join Date
    Jul 2006
    Location
    Grinnell, IA
    Posts
    10
    Boat
    22v
    Rudder Rebuild?
    I have a 2004 22V and my steering is very tight under throttle. I have a new steering cable and it turns very smooth at idle which makes me think my rudder needs rebuilt. Are there any tricks to this, or advice before I tear into it?
  2. #2
    Have you greased it lately?
    Grumble, Grumble
  3. #3
    Join Date
    Jul 2006
    Location
    Grinnell, IA
    Posts
    10
    Boat
    22v
    I did grease it when I changed the cable. There is a small amount of play in it when I pull the rudder back and forth, would this cause it to become tight when there s pressure on it under throttle?
  4. #4
    Yes, yes it will. Was the shaft worn? You may be better off replacing the whole rudder assembly.
    Grumble, Grumble
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
