Results 1 to 13 of 13
Thread: Speed set adjustment/calibration
  1. #1
    Join Date
    Apr 2007
    Location
    Mt. Pleasant, SC
    Age
    54
    Posts
    187
    Boat
    '07 22 Ve'
    Does anyone have a clue as to how to calibrate ‘07 era speed set settings? I just installed Nautic Logic gps based speed control, and would like to make it fairly accurate.
    Thanks!
  2. #2
    Grumble, Grumble
  3. #3
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    50
    Posts
    28,195
    Boat
    Dont have an answer, but good to hear from you!
  4. #4
    Join Date
    Apr 2007
    Location
    Mt. Pleasant, SC
    Age
    54
    Posts
    187
    Boat
    '07 22 Ve'
    Thanks for the replies, guys, but my speedo is different, pic attached. I think there is a way to adjust through the speedset UI, but have no idea how. Any help appreciated!
  5. #5
  6. #6
    Join Date
    Apr 2007
    Location
    Mt. Pleasant, SC
    Age
    54
    Posts
    187
    Boat
    '07 22 Ve'
    Thanks KoolAid, can't wait to try this!
  7. #7
    Join Date
    Feb 2019
    Location
    Texas
    Posts
    24
    Boat
    2007 22ve
    I have a question about the speedset. I just got a 2007 22ve and i cant seam to get the cruise control to set. How do you set your speed?
  8. #8
    Join Date
    Feb 2019
    Location
    Texas
    Posts
    24
    Boat
    2007 22ve
    My speedset looks the same as Weil Thing above.
  9. #9
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    50
    Posts
    28,195
    Boat
    If the rocker switch is on and illuminated and speed set does not set and hold, speed up or slow down on command, likely need a new touch pad board.
  10. #10
    Join Date
    Feb 2019
    Location
    Texas
    Posts
    24
    Boat
    2007 22ve
    Quote Originally Posted by chpthril View Post
    Ok so the touch pad works i can get to the set up page and change my display and stuff and i dont have to turn on a rocker switch to do any of that.
  11. #11
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    50
    Posts
    28,195
    Boat
    The center button on the touch pad is the "set" button. When you reach your desired speed, push it. When the speed set takes over, bury the throttle to WOT.
  12. #12
    Join Date
    Feb 2019
    Location
    Texas
    Posts
    24
    Boat
    2007 22ve
    What rocker switch is it to turn on maybe i need to turn it on for the cruise control to work?
  13. #13
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    50
    Posts
    28,195
    Boat
    "Cruise Control" On off. You can see it in the pic above.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
