Results 1 to 5 of 5
Thread: Nautic Laugic NL4-SR
  1. #1
    Join Date
    Apr 2007
    Location
    Mt. Pleasant, SC
    Age
    55
    Posts
    187
    Boat
    '07 22 Ve'
    Has anyone installed one of their GPS gadgets in your boat? It goes between the paddlewheel and the helm, and changes your speed sensing from the paddlewheel to GPS. My boat surges so badly while towing (especially when making any turns) I'm thinking of giving it a try.
    Thanks for any info!
  2. #2
    Join Date
    Jun 2014
    Location
    Lethbridge, Alberta, Canada
    Posts
    186
    Boat
    2006 22V
    Yep, installed one last season (my paddlewheel had stopped working properly BUT I didn't want to give up the depth and temperature sensors which were still working). It is a simple install (takes about 10 minutes). I did need to calibrate my speedo afterwards though. I used a hand-held GPS unit to calibrate. Has been super solid - it was a great purchase.
  3. #3
    To echo on what macteacher2 said, it is simple to install and works great. I spent more time figuring out where to put the GPS puck than I did plugging the thing in. To calibrate mine, I used my cell phone and calibrated at 10, 20 and 30mph. Using those speeds allowed me to fine tune the speedos and now are with .4mph of what my phone says at any given speed.
    Only thing I have against it is a cold GPS lock can take 2-3 minutes, but that is minor issue for me. I'll start the boat and let it idle a bit to give it time to acquire lock.
  4. #4
    Join Date
    Apr 2007
    Location
    Mt. Pleasant, SC
    Age
    55
    Posts
    187
    Boat
    '07 22 Ve'
    Thanks for the replies guys!
  5. #5
    Join Date
    Sep 2018
    Location
    Liberty Lake, WA
    Posts
    1
    Boat
    24ve 2007
    The surf wake on my 2007 24ve is great, but the paddle-wheel signal to the Tige Speed Set was +/- 0.4 mph, which was too imprecise for speed control. Installed Nautic Laugic’s NL4-Sr GPS this weekend. The Speed Set now is working great with little effort to keep the surf wake clean. Easy install. Highly recommend Nautic Laugic.
    Mounted the GPS antenna forward of the port tower pole (for good sky exposure) and routed the GPS antenna cable from the storage compartment behind the observer’s seat through the nearby engine ventilation port to avoid having to drill any visible holes.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
