Page 4 of 4 FirstFirst 1234
Results 46 to 50 of 50
Thread: Bow Drains Install
  1. #46
    Join Date
    Jul 2007
    Location
    Polk City, Iowa 50226
    Age
    48
    Posts
    1,513
    Boat
    08 RZ2
    01 21 V
    I need to check but does it have the drain tubes. I put stuff in what I thought was dry storage and it gets wet all the time. So I will be in search of these tubes.
    Sam
  2. #47
    Join Date
    Jun 2009
    Location
    Hutto Texas
    Age
    47
    Posts
    52
    Boat
    2005 24V
    I did this to my ride last season. It keeps things dry, and with no carpet in bow storage, I don't worry about mildew. I think so far this has been the most time saving upgrade/modification I have done yet.
    Thanks for taking the time to do the documentation.
  3. #48
    Join Date
    Apr 2010
    Location
    Dallas, TX
    Posts
    15
    Boat
    2006 24Ve
    Quote Originally Posted by chpthril View Post
    On 1 side, the hole was right in the corner of the bow storage bulkhead. The other side was about 1.5" toward the gunwale. Both where about 1" holes. Press your fingers along the carpet and you should feel the carpet give way when you hit the hole.
    If I had known the drain holes were there, I would have filled them in long ago. I would rather have standing water in the bow, that I have to shop-vac out, then have water running into the storage console where we put all our stuff that we want to keep dry.
    Mike - Why couldn't you drill a hole straight down? I'm assuming there is space under the front storage and that it would drain back to the bildge? I need to do something to move the water up there as well.
  4. #49
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    50
    Posts
    28,191
    Boat
    Quote Originally Posted by Yadatbeme View Post
    Its not open space on the Ve, it the core.
  5. #50
    Join Date
    May 2019
    Location
    United States Texas
    Posts
    1
    STEP 4: With the hose and passthru cut and testfit, cut glovebox drain hose and install tee. Next I applied a bead of sealer around the end of the brass passthru and slid it thru the hole a little further than needed AllPetsExpert
, about 1/4in. I then applied another bead of sealer and pulled it back flush with carpet to form a seal/bond.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
