Results 1 to 10 of 10
Thread: Wetsounds rgb led question
  1. #1
    Who has installed a wetsounds rf rgb mc v2 that doesn’t get hissing from the speakers. I would like to know how you have it wired for power.
  2. #2
    2015 and later are powered by the PDM so that doesn't help much. Does it hiss when the RGB wires are unplugged? Meaning the four rgb wires unplugged and only the power and ground hooked up to the controller.
    It's dangerous to go alone! Take this.
  3. #3
    Join Date
    Sep 2008
    Location
    Helena,MT.
    Posts
    973
    Boat
    2019 zx5 fully tricked
    Not sure but guessing it’s coming from the amps
    surf till u die.
  4. #4
    I havent had time to troubleshoot it, I am going to run power and ground directly to the battery to see if that fixes the humming/hissing noise. It is for sure not the amps as it only makes noise when the leds are lit.
  5. #5
    What worked for me was power/ground the stereo head unit directly to the battery
  6. #6
    The stereo? So it was on all the time? Or you put a switch in line?
  7. #7
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    50
    Posts
    27,667
    Boat
    I'd gather he's referring to the constant 12v supply only, not the IGN turn on.
  8. #8
    hmm... I wonder if I have installed incorrectly... I just have one red and one black.. I assumed the red went somewhere into the ignition... my yellow wire is directly to perko switch, that does include all of my other items though..
    I do feel like it only hums from the rgb controller though.. when I turn the power to the controller off the hissing/humming goes away.
  9. #9
    Join Date
    Oct 2018
    Location
    Parker, TX
    Posts
    28
    Boat
    Tige R23
    Quote Originally Posted by Carranza913 View Post
    If possible, use a battery that is not connected to anything else. This will prove if noise is coupling through 12v power/ground or coupling through the 4wire led cables into rca’s.
  10. #10
    Just FYI I ran direct to the Perko switch and grounded directly to battery and put a switch inline. No hissing. Works perfect!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
