Results 1 to 10 of 10
Thread: Considering a 2016 RZX, Pros/Cons
  1. Considering a 2016 RZX, Pros/Cons
    Hi Tige Owners, I'm buying a new boat. One that came up I need to look at is the RZX and I found a well equipped 2016. Curious on what I should look for, must have vs. nice to haves.
    Any major issues with the 2016? I believe it has the 575, but need to confirm. I know the RZX will surf amazing, how is the wakeboard wake at 19 to 23?
    Does the ZX replace the RZX in 2019? So is the 2016 the first year of the RZX?
    Help me decide. RZX, Ri237, Fi23, SE550, XT23.
  2. #2
    Join Date
    Aug 2015
    Location
    Salt Lake City, Utah
    Posts
    1,468
    Boat
    2017 RZX3, 2013 MB F24, 2000 21V
    Welcome to the sight. There has been a lengthy thread on a 2016 RZX. Bottom line: If if has the 575 you will be very happy with it. If it does not I think I would steer clear unless it's a flat out smoking deal and you plan to upgrade the engine or transmission.
    If I was just coming into boating and knew what I know now, I probably would have gone Centurion or Supra. We have grown to love Tige and the great Tige Family so we'll be here a while.
    There's great info here:
    http://www.tigeowners.com/forum/show...X+supercharger
  3. #3
    Join Date
    Sep 2017
    Location
    Minneapolis, MN
    Posts
    274
    Boat
    2019 Tigé
    Depending on your location, 575 may not be necessary. At elevation definitely go with 575. Here is MN(800'), the Raptor 440 is fine. 2016 did not have the new Alpha E2 power tower, which I think is a must have. I put my boat on a boat lift with a canopy and need to raise/lower the tower every time.
    The ZX does not replace the RZX series, it is a whole different model and hull shape.
    RZX wakeboard wake is amazing. I'm intermediate/advanced level rider, ride at 75'(could go 80') 22.5MPH, front ballast 100%, rear ballast 100% full. Then, depending on number of people, TAPS at 2-5 and Pnp empty to 75%. Wake is firm, big, and great kick. It's more vertical versus older models which seem to be more rampy. Only wakeboard wake I've ridden that has topped it would be G23.
  4. #4
    Join Date
    May 2014
    Location
    Vancouver Island, BC, Canada
    Posts
    1,434
    Boat
    2016 RZX3, 2014 R20 with taps 3
    Both great boats. Commented on the Facebook page so I’ll keep it simple here.
    Some say the 440 isn’t right but it’s because of the prop, without the proper prop it’s garbage but once you get things worked out and prop it right it’ll push anything you throw at it.
  5. #5
    Join Date
    Feb 2004
    Location
    St. George, Utah
    Posts
    5,437
    Boat
    2019 25 LSV, 2016, 2015 G23, Malibu 247, X45, 2005 24V, 2002 21V
    Quote Originally Posted by bsreid View Post
    In the other thread, I am not sure I bought the guy's complaints completely. I am not going to read the whole thread again, but it seemed he expected the 440 to do OK at 5000 feet elevation, IIRC. If the 440 can't push it at or near sea level, then something is wrong with the motor, or the prop needs a different pitch.
    Be excellent to one another.
  6. #6
    Join Date
    May 2014
    Location
    Posts
    1,434
    Boat
    He was trying to run full ballast plus 11 people with the wrong prop at 6000ft. I can run full pnp, 900 lead, 6 people, taps 3 engaged surfing at 11.4 no problem at just above sea level. So drop weight down a bit and you’ll be good to go.
  7. #7
    Join Date
    Sep 2017
    Location
    Minneapolis, MN
    Posts
    274
    Boat
    2019 Tigé
    Quote Originally Posted by sivs1 View Post
    I also wanted to point out, make sure you are comparing apples to apples. The only boats you have listed that is a good direct comparison is the Ri237, the rest are not direct competitors or comparisons to the RZX.
    The Fi23 and Xt23 are more comparable to R23/Z3. The SE550 is a big boat, more comparable to ZX5.
  8. #8
    Join Date
    May 2012
    Location
    San Angelo, TX
    Posts
    848
    Boat
    2015 Z3 w/AVX
    I would like to echo what these guys above are saying - unless at elevation, you do not need the 575. If propped right, the '16 RZX will move some weight and make a wave just fine!
    We played around with a '16 model quite a bit last summer - threw quite a bit of lead at it and it performed very well. I will say, the 2/1 transmission is awesome and made a world of difference - but I would not discount the '16 model RZX just because it didn't have one.
    So I am not a wakeboarder at all anymore - however, at around 20 mph the wake looks amazing. Wakeboarding hurts too bad these days to even try it out though...
  9. #9
    Join Date
    Jul 2015
    Location
    Orange County
    Posts
    1,769
    Boat
    2019 ZX5/ZX1
    The problem with 440 1.5/1 drivetrain in the RZX is that its marginally passable in terms of being enjoyable when not doing water sports if propped to push big weight. Also, big weight is a pretty loose term. Can it push weight if you drop the pitch down to nothing? Sure, at the expense of 5k on the Tach and with the caveat that the boat will be a slug to cruise around in.... I just want to make sure people understand that. It will work but it isnt ideal if you are running say overflows and some lead. The 2-1 is for real, I wouldnt own a big RZX line boat without it personally especially if you wakeboard.
    On a side note go get into a 19 with the blower and the 1.75 ratio. It is the best thing I have ever been in. Sips fuel, wakeboards heavy, surfs with 5 tons in the boat and cruises in the upper 30s. Surf Rpm in a ZX5 with that ratio and big big weight was like 2960..... let that sink in. Unreal
  10. #10
    I’ve spent the last year messing with a 2016 RZX, 150 hours on the water, and anyone who’s been in my thread about it, knows my feelings.. I’ll keep it cool here, and stay off my rants.. I live in the Sierras, and run from sea level to 6200’ within an hour and a half at a dozen different lakes. I regularly run at probably far different elevations than most. I’ll also be the first to admit that maybe I expect too much. Enough said. I’m a gear head, and understand how stuff works. I’m also not opposed to changing props for different weekends, at different elevations, which I’m sure some people aren’t willing to do.
    The 2016 rzx is good to about 2000’, with a 15” x 12” prop and 4000’ with a 15”x11” prop, if you want to run a lot of weight. If you aren’t as concerned with weight, you can cheat that some. Bsreid is running a 16” prop, which I want to play with, but haven’t yet, but I know he’s been a lot more happy with his setup.
    Personally I wouldn’t run the 440 again, at any elevation, with a 1.5:1 drive, that’s just me, I might be the minority in that feeling. I love everything else about the boat. I’ve never folded my tower, so I can’t attest to the amount of convenience of the E tower.
    Guessing you’ll be happy with the Supercharged motor, as the 440 is really close to being good, it literally feels like it’s probably like 10% underpowered with that drive.
    Either way, it’s a great boat, with a great wave.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
