Results 1 to 5 of 5
Thread: Stereo control
  1. Stereo control
    Hi all, just curious what the dial under the tige touch screen does, it’s a Polk stereo dial which I’m assuming increases the bass but am unsure.
    Also the plastic that surrounds the tower speakers are cracked, can they be replaced or don’t worry about them. They look like they just hide the mounting hardware and are just cosmetic. Sorry I don’t have pics
    The boat is a 2015z3
    Thanks
    Brian
  2. #2
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    50
    Posts
    27,609
    Boat
    There will be a Wet Sounds sub level control that typically gets mounted by Tige, just below the bottom edge of the helm panel.
    The beauty collars are a Tige only part and used to only come when you purchased the speaker direct from Tige. Ive heard they may have been discontinued. Id either remove them or take them off and repair/re-coat them.
  3. Thanks for the quick reply, any idea how the collars can be removed?
  4. #4
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    50
    Posts
    27,609
    Boat
    The collar is pinched between the pod and tower. It comes off when the pod is removed. This is done by removing grill and speaker driver first. Then remove the two 13mm headed bolts from the inside of the pod, that secure it to the tower. Lower pod and find the white connector to separate.
  5. Thank you for the info
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
