Results 1 to 6 of 6
Thread: 2015 Z3
  1. 2015 Z3
    Hi all, This may be a dumb question but can the front bow fill cushions be removed in a z3 2015? I’m getting it cleaned and ready for storage and there seems to be a lot of water under the cushions.
    Thanks, I just bought the boat and am still learning a lot about it.
    Thanks
    Brian
  2. #2
    Join Date
    Aug 2015
    Location
    Lewisville, TX
    Posts
    104
    Boat
    Tige 2015 Z3
    Yes they can. They are just in there very tight.
  3. Ok, any chance you can give me some direction? Do I pull up from the front or the back of the front cushion?
    Thanks
    Brin
  4. #4
    Join Date
    May 2012
    Location
    San Angelo, TX
    Posts
    838
    Boat
    2015 Z3 w/AVX
    I pull the little nose cushion out first - then start the big piece by pulling the middle up into a slight bend/curve. Then with the front compartment seat backs closed, start on one corner by working it past the vinyl back rests. You can't just "pull it up" real fast - you just have to "work it" past the seat backs....again, its a tight fit.
    The cooler cushion and the windscreen all come out as one big piece of the front "cushion".
  5. #5
    I pulled the front compartment seat backs off. Also had to remove my speakers as I have the led rings so they stick out a little extra.
    Sent from my SM-G892A using Tapatalk
  6. Thanks, so let me ask this, is there any worry if I left them alone and let the water dry up naturally?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
