Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 32
Thread: Surf toon
  1. #16
    Join Date
    Mar 2014
    Location
    Abbotsford BC Canada
    Posts
    785
    Boat
    2009 Tige 22ve
    Years ago when I was down in Florida on any of the lakes pretty much every house has a tourney boat of some kind and a pontoon boat. You have the play boat and the party boat.
  2. #17
    Join Date
    Oct 2012
    Location
    Jacksonville, FL
    Posts
    317
    Boat
    2012 RZR
  3. #18
    Join Date
    Jun 2015
    Location
    Phoenix
    Posts
    176
    Boat
    2006 24Ve
    The wave on this thing sacked out with 20k lbs will rival our tour boat friends on Powell...
  4. #19
    Join Date
    Aug 2015
    Location
    Salt Lake City, Utah
    Posts
    1,362
    Boat
    2017 RZX3, 2013 MB F24, 2000 21V
    Really interested in how this surf wave works. I watched the video, but it didn't show much. A pontoon has 2 or 3 hulls really, so what happens with the water running down between the logs?
  5. #20
    Join Date
    Mar 2014
    Location
    Posts
    785
    Boat
    2009 Tige 22ve
    Shows a picture in the link above. Looks to be a pontoon-less pontoon boat that has a full hull.
    Attached Images Attached Images
  6. #21
    Join Date
    Aug 2016
    Location
    Meridian, Idaho
    Posts
    51
    Boat
    2017 RZ2
    Quote Originally Posted by D&P Powell View Post
    It will take https://www.youtube.com/watch?v=dNiaYARLen8 to a whole new level, that's for sure!
    that was awesome!!
    We've said a couple times need a friend to get the party barge so we can have the best of both worlds.
  7. #22
    Join Date
    Oct 2014
    Location
    Great Faces, Great Places--South Dakota!
    Posts
    1,213
    Boat
    Used to have gangsta lean 24Ve; then GSA F24 Tomcat, now a 2016 Supra SE450. Onward we roll!
    Quote Originally Posted by BCRider View Post
    Look closer!
  8. #23
    Join Date
    Feb 2016
    Location
    Boise, ID
    Posts
    1,598
    I think it might be closed off im between toons. Weve always talked about having running surface across the entire beam in the back half of the toon and having an angle that comes all the way up to the deck and meets with an aluminum underskin(to keep water away from wood deck and help planing).
    Regardless Id say its not toons in the rear because even the largest toons on the market are 36". They are advertising the PCM engines at 409, whicj in the past was the 6.0L GM platform. Not really current on PCM these days as they are Nautique/Centurion/Supreme, but I know people are all about the 6.2 DI they are putting out.
    Regardless, I doubt either package would ever fit in a single toon so theres something going on under the deck in the rear end.
    PCM does do a GM 5.3L configuration, but I dont see it pushing this barge at the stated weight/length...
  9. #24
    Join Date
    Mar 2012
    Location
    Ft Gibson Lake, OK
    Posts
    874
    Boat
    1997 Pre 2150 WT
    Almost has an older deck boat look to it. Be interesting to see some more on it.
    1997 Pre 2150 WT
  10. #25
    Join Date
    May 2013
    Location
    Sartell, MN
    Posts
    911
    Boat
    2007 22Ve & 2015 Boston Whaler SS150 Previous: 2014 G23, 2013 Z1, 1997 Marada I/O
    I don't care how beautiful you are, or if it is a Pontoon...TAKE OFF YOUR DAMN SHOES! She could even take off more than her shoes...just saying
    If you read through it, you will see that this is a Mark Overbye project. He is the founder of Gekko Ski Boats. He has alot of connections in the industry over the years. It sounds like they have a deal with PCM, this will be an inboard (v-drive?) toon.
    Last I knew, after Mark got Gekko back he tried to revive it and then was acquired by Floe International. They had been known for their docks, but they wanted Mark to help launch their boat line, which started with the Afina
    http://www.floeintl.com/floecraft-afina/
    Mark was working the Floe Afina booth last year at the Minneapolis boat show. This is your real party barge.
  11. #26
    Join Date
    Feb 2016
    Location
    Boise, ID
    Posts
    1,598
    Thanks for dropping the knowledge Dandy. Funny thing, is this is the second time Ive bumped into a FLOE product. recently. Not sure if youve seen these but here comes another entrant to the wake segment
    https://www.floeintl.com/varatti-boats-draft/
    Found it funny how close their name is to Pavati
  12. #27
    Join Date
    Jul 2012
    Location
    Henderson, NV
    Posts
    710
    Boat
    '14 Z3
    interesting history that gekko is now dead and varatti is up. no coincidence there.
    looking at the varatti, couple call outs..
    steering wheel is the same smart wheel that tige is using.
    says 9 patents on the surf system. hard to tell but looks like it could be close to nss? either way not sure I would call it innovative with a hydraulic tab.
    5000lb dry weight and 2400lbs of ballast and the options are mercruiser 320hp and 370hp. props make a big difference but seems light for a boat of that weight in today's surf-centric world?
    playacraft has had a v8 powered tooner for some time so wonder how close the design is to that boat?
    2012 22ve.. RIP 4/17
    2014 Z3.. Surf away
  13. #28
    Join Date
    May 2013
    Location
    Sartell, MN
    Posts
    911
    Boat
    Quote Originally Posted by freeheel4life View Post
    Before Gekko was closed/acquired they were working on a boat that was going to be called the Komodo. The teasers and info that I had gotten from Mark, indicated it was going to be a wide bow or pickle fork and the big integrated Gekko platform was going away. Mark had begun work on the designs and the molds. I am fairly certain that this boat is what would have been the Gekko Komodo.
  14. #29
    Join Date
    May 2013
    Location
    Sartell, MN
    Posts
    911
    Boat
    Maybe this is the Wake Tractor version of the SurfToon!?
    Sent from my VS995 using Tapatalk
  15. #30
    Join Date
    Jun 2018
    Posts
    101
    Boat
    '98 pre2200i
    That varratti is interesting. It’s bow is as low as my 98 DD. And the hull looks really similar too IMO.
    Surf pontoon would be great if it actually works. Maybe now I can convince friends to get a pontoon, you know for the great surf wave, and less important aspect of being the party barge. Lol.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
