Results 1 to 3 of 3
Thread: 22V tower leaking into storage
  1. 22V tower leaking into storage
    So the bow-port hull-to-tower attachment point is loose on my 22v. Obviously I know I need to tighten it, but I’ve noticed it’s been leaking into my storage compartment.
    Anyone replace the gaskets or should I just use home caulk to seal it up?
  2. #2
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    50
    Posts
    27,666
    Boat
    If it's the OEM time tower it needs a rubber pad under the foot. Much better then trying to cailk around it. Snug up the nut with a 7/8" deep well socker iirc. 3/8" Allen for the rear feet.
  3. Quote Originally Posted by chpthril View Post
    Yeah I’m almost positive it’s the oem tower and yeah there’s a rubber foot under the tower and there is a plastic looking gasket in decent shape between the tower and the hull. So just tighten it and it’s largely water proof on its own?
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
