Results 1 to 2 of 2
Thread: Could X-over be causing bags to fill?
  1. #1
    Join Date
    Sep 2014
    Location
    Lethbridge, AB, Canada
    Posts
    240
    Boat
    2008 Z1
    Question Could X-over be causing bags to fill?
    I added an impeller Jabsco pump with 1" lines as a crossover to my setup last year. My existing ballast has 3/4 inch lines and aerators. I am now experiencing one (usually only one) of the rear bags taking on water when the boat is docked or just floating. Could this be because of the newly installed cross over system? I'm not sure timing is exact but it never used to do that.
    2008 Tige Z1 Limited Ronix Edition
    360 hp, Fly High ballast, Alpine, JL Audio, Kicker, Wetsounds audio
  2. #2
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    50
    Posts
    27,611
    Boat
    not unless the other side is full and you find it not full. Likely need to rework the fill line.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
