Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: THE Quest ForThe Best Wave
  1. #1
    Join Date
    Jul 2017
    Location
    Nashville
    Posts
    247
    Boat
    2000 21v Riders
    This is info for what I found.
    BOAT.. 2000 21V riders 350 merc blue Walter, acme 1433. Lockers have 750 LBS high fly each, bow has 725 LBS Y sac high fly that fills to 600-650, suck gate, Nauticurl. ground down to fit my hull.
    ME... 50 years old 5'8" 175 LBS Surfing 8 or 9 years. I can surf regular or goofy not equally but close. Advantage regular.
    WATER..Glass 84 degrees. min depth 25 foot
    Wave Regular
    1 LISTED 1100 LBS no weight front SPEED 10.5-10.9 TAPS 6 LENGTH 16-17 foot HEIGHT 22"-24" more flat not much curl,splashy lip PUSH moderate
    2 LISTED WITH A GATE 1100 LBS no weight front SPEED 10.9-11.2 TAPS 4.5 LENGTH 17-18 foot HEIGHT 23"-25" a little steeper a better curl, solid lip PUSH moderate/high
    3 EVEN WEIGHT With GATE SIDE see boat above Extra 225 surf side, SPEED 10.7-10.9 TAPS 4.5 LENGTH 20-21 foot, HEIGHT 23"-25" good curl, solid lip PUSH moderate/high
    4 EVEN WEIGHT With GATE UNDER Extra 225 surf side SPEED 10.7-10.9 TAPS 4.5 LENGTH 21-22 foot HEIGHT 28"-30" much steeper strong curl, hard lip PUSH high
    Wave Goofy
    5 LISTED 1100 LBS no weight front SPEED 10.5-10.9 TAPS 6 LENGTH 18-19 foot HEIGHT 24"-26" medium steep not much curl,splashy lip PUSH low/moderate
    6 LISTED WITH A GATE 1100 LBS no weight front SPEED 10.9-11.2 TAPS 4.5 LENGTH 17-18 foot HEIGHT 26"-28" a little steeper a better curl, solid lip PUSH moderate
    7 EVEN WEIGHT With GATE SIDE see boat above Extra 225 surf side, SPEED 10.7-10.9 TAPS 4.5 LENGTH 21-22 foot, HEIGHT 28"-30" strong curl, hard lip PUSH high
    8 EVEN WEIGHT With GATE UNDER Extra 225 surf side SPEED 11.0-11.3 TAPS 4.5 LENGTH 21-22 foot HEIGHT 24"-26" flat low curl, splashy lip PUSH low
    I worked on all of these different setups for about 6 hours yesterday. I did try lots of other combos but they didn't produce anything worth mentioning just low push or just crap. It was a lot of fun. Definitely wore this old man out.
    With all of this said my setups will be Reg #4 goofy #7 until I try slappers. They need to be built yet I am not sure they will do better, but I am not afraid to try. I am going to try to get all the videos together. I wanted to do them blind so you can pick the wave you think is the best. Some of them were obvious what they were. So I am going to reshoot them. This is a picture of of my under suck gate.
    Attached Images Attached Images
  2. #2
    Join Date
    Mar 2014
    Location
    Abbotsford BC Canada
    Posts
    776
    Boat
    2009 Tige 22ve
    UMMM, that's supposed to go on the side, not the bottom
  3. #3
    Join Date
    Jul 2017
    Location
    Nashville
    Posts
    247
    Boat
    2000 21v Riders
    I know but my regular wave loves it there. My goofy hates it. So on the side for goofy.
  4. #4
    Join Date
    Aug 2013
    Location
    Idaho
    Posts
    97
    Boat
    2001 2300v
    Interesting idea to place it in the spray pocket. I may have to build a suck gate now
  5. #5
    Join Date
    Jun 2013
    Location
    Langley, b.c.
    Posts
    480
    Boat
    2010 Tige 22ve
    I did the same thing with the one I built as well. It does work, I just didn't have enough time to play with
  6. #6
    Join Date
    Jul 2017
    Location
    Nashville
    Posts
    247
    Boat
    2000 21v Riders
    I did this quest because a lot of guys love the list. and needed to see for my self if I could get a better wave from the boat. If I could.Then that was the direction I was going to go. (All in) Transfer pump the hole 9 yards. Most of the 6 hours were spent with the boat in a list. Working to get it as good as I could. I wanted it to work. I know the 1100 LBS is what they are doing so it was a matter of getting it fat. In The end it just wasn't there. (for me) I showed the under gate so you can tell what I was talking about. It is not a how people use them normally. I am not normal. For the people who list there boat. You are doing nothing wrong. and don't stop because I didn't prefer it. It is just my option.and wanted to see what you all love about your wave.
    I guess the next question is should I put the work into the videos? or are you all just not that interested? If so is 30 seconds enough for each wave?
  7. #7
    Join Date
    Dec 2015
    Location
    Denver, CO
    Posts
    828
    Boat
    2007 22ve
    I’d like to see them
  8. #8
    Join Date
    Feb 2011
    Location
    Calgary, Alberta
    Age
    39
    Posts
    1,781
    Boat
    2013 Tigé Z1 Vx
    I'm very interested to see your results. I suggest you just post them to Youtube. I did a whole video series on this as well and they get tons of views. I suggest showing the waves back to back to back. I find 10 seconds is about right. Just add some text or put a picture in the corner showing the configuration.
    I am like you - must tinker to be weird. Normal sucks.
  9. #9
    I am assuming your are filling your bow sac for the evenly weighted runs?
    Happen to be at the lake and heading out in the am, going to try the under configuration. I love the gate waves, GF insists the listed is better.
  10. #10
    Join Date
    Dec 2015
    Location
    Denver, CO
    Posts
    828
    Boat
    2007 22ve
    Tell her that she’s just a simple women with a brain the third the size of ours, it’s science.
    (Credit Mr. Ron Burgundy)
  11. #11
    Quote Originally Posted by Jetdriver View Post
    Lol, ya I'll try that, see how far that gets me
    Everything that goes wrong when she's on her set is because the wave sucks ...sigh...
  12. #12
    2004 22v
    1100 surf side
    700 off side
    600 in bow
    Swell wake under off side
    Taps 4.5
    Wave was destroyed at 10.7 up to 12.
    Stopped and put the swell wave gate on the side, back to our so so wave.
    It was worth a shot.
  13. #13
    Join Date
    Jul 2017
    Location
    Nashville
    Posts
    247
    Boat
    2000 21v Riders
    aspidaso Your hull is completely different than mine. None of the info In this post will apply to your hull. I am not sure but I think it will only apply to 1999-2003 21/23 V I am sure if I am wrong someone will help me out.
  14. #14
    Roger that, but it sounded like a good experiment!
  15. #15
    Join Date
    Jun 2005
    Location
    NorNev
    Age
    45
    Posts
    6,246
    Boat
    '00 22i Custom Fox Edition
    Just to throw in a little 21v data:
    400 both lockers
    Zero bow weight
    Sacgate (similar to Nauticurl)
    Taps 4.5 (I think)
    10.5 mph
    2 adult(1m,1f), 3 small kids
    Rider 5’10”
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
