Results 1 to 4 of 4
Thread: Tower speaker options
  1. #1
    I have 4 of these kicker tower speakers on our 22ve They are 6" kickers in Tige cans. Is there a replacement option speaker that would fit the can and throw louder sound or is it inevitable that an upgrade should just happen. Thoughts appreciated
    Sent from my SM-G950W using Tapatalk
  2. #2
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    49
    Posts
    27,255
    Boat
    If they are still driven by the original 350.4, you can upgrade the amp wattage for more output. However, they still will not be as efficient at wake range protection as and HLCD.
    There are a couple of possible HLCD options, but slim ones. I cant recall what the pod's ID and OD are. You will need at least and 5" ID and maybe up to a 5-1/8" opening and right at a 7" OD in order to fit something like the Kicker KMS674C
    Mikes Liquid Audio: Knowledge Experience and Customer Service you can trust-KICKER WetSounds ACME props ARC Audio FlyHigh Custom Ballast Clarion LifeForm LED Polk Rockford And More
  3. #3
    Thanks kindly. I will take a measure. Appreciate your expertise.
  4. #4
    Join Date
    Feb 2004
    Location
    Overland Park
    Age
    40
    Posts
    553
    Boat
    2006 24ve
    I build a system for my 2006 24 ve way back when wet sounds was just a dream, I think only NVS had starting using HLCD's at that point.
    I have 2 of these on my tower: https://www.parts-express.com/eminen...eaker--290-662
    They should fit in your speaker can.
    Then in the other 2 cans you need HLCD's. I used these https://www.parts-express.com/eminen...8-ohm--290-522
    Use this horn for the HLCD: https://www.parts-express.com/eminen...ProductDetails
    You will have to fabricate a mounting plate which isn't hard!
    The sound is really amazing actually. The only other thing I added was crossovers and mounted that next to my amps. I used this crossover: https://www.parts-express.com/eminen...00-hz--290-635
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
