Results 1 to 10 of 10
Thread: Cleaning and maintaining gatorstep
  1. #1
    Join Date
    Apr 2017
    Location
    Spokane, WA
    Posts
    321
    Boat
    2009 24ve
    Curious on what everyone has been using to clean and maintain their gatorstep?
  2. #2
    Join Date
    Mar 2014
    Location
    Abbotsford BC Canada
    Posts
    785
    Boat
    2009 Tige 22ve
    Ultra Deck which is another company that does the foam decking had a picture on their IG using this with a brush: https://www.meangreendegreaser.com/p...uper-strength/
  3. #3
    Join Date
    Aug 2015
    Location
    Salt Lake City, Utah
    Posts
    1,371
    Boat
    2017 RZX3, 2013 MB F24, 2000 21V
    I use Totally Awesome heavily with a brush then suck it all up with a wet/dry vac. Seems to work well.
  4. #4
    Join Date
    Feb 2004
    Location
    St. George, Utah
    Posts
    5,407
    Boat
    2019 25 LSV, 2016, 2015 G23, Malibu 247, X45, 2005 24V, 2002 21V
    https://scwake.com/keep-seadek-clean...ke-boat-juice/
    I think a brush is key. But the SCwake stuff does work really well, I use it.
    Whether good old simple green or Totally Awesome would work just as well merits investigation. But nothing will work so well without a brush and some elbow grease.
    Be excellent to one another.
  5. #5
    Join Date
    Oct 2010
    Location
    Murrieta, CA
    Age
    50
    Posts
    924
    Boat
    Previously 2004 22i, 2014 Z1, now 2015 Z3
    I've been following this thread as I have been wondering the same thing. Larry, does it matter what kind of brush in your opinion?
  6. #6
    Join Date
    Apr 2017
    Location
    Spokane, WA
    Posts
    321
    Boat
    2009 24ve
    I might have to try some of that cleaner!
    I ended up using the RAD clean all from hula boat care as it said it was good to use on Eva foam surfaces. I sprayed a lot on the soak it well then used a brush to scrub and wiped off with a towel. Seemed to work well
  7. #7
    Join Date
    Feb 2004
    Location
    St. George, Utah
    Posts
    5,407
    Boat
    Quote Originally Posted by D&P Powell View Post
    I don't think so, but I have not tried a wide variety of brushes. Obviously, if you attack with one of those BBQ grill brushes, it will be too harsh, so something soft is good.
    I should also say, that I only clean the foam when I have a water supply. It seems that for it to work best, you have to be able to rinse it off. So I do it in the driveway with the hose, or at the lake with a bucket of water and let it go down into the bilge.
  8. #8
    Join Date
    Oct 2010
    Location
    Murrieta, CA
    Age
    50
    Posts
    924
    Boat
    This forum never ceases to amaze me! Thank you Larry for the recommendation on the SC Boat Juice! I took our boat to the local DIY car wash. I followed the instructions on the bottle and had a bucket of water as I cleaned all the gator step. After spraying, scrubbing, and rinsing with a bit of water from the bucket, I then used the car wash wand on rinse mode to clean it all up. I will never use anything else to clean it. I’m not sure these before and after pictures do it justice. I used it on all the gator step in our boat, and used less than 1/4 of the bottle.
    Before Picture
    After using SC Boat Juice
    Thanks again Larry for the recommendation!
    Last edited by D&P Powell; 07-22-2018 at 06:59 PM. Reason: Fixed picture orientation
  9. #9
    Join Date
    Feb 2004
    Location
    St. George, Utah
    Posts
    5,407
    Boat
    Glad to hear you got good results with it. It seems your boat is so happy it turned itself sideways.
  10. #10
    Join Date
    Oct 2010
    Location
    Murrieta, CA
    Age
    50
    Posts
    924
    Boat
    Quote Originally Posted by talltigeguy View Post
    - Fixed it.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
