Results 1 to 5 of 5
Thread: checking engine oil level while in water
  1. #1
    Join Date
    Nov 2016
    Location
    Union Michigan
    Posts
    151
    Boat
    2014 RZR
    If the boat is floating in water, how acurite is the dipstick reading on an Indmar 5.7?
  2. #2
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    49
    Posts
    27,428
    Boat
    That supposed to be the most accurate they say
  3. #3
    Join Date
    Nov 2016
    Location
    Union Michigan
    Posts
    151
    Boat
    2014 RZR
    Reason I ask is this. Indmar says to level the boat to check oil. While floating, neither the floor or engine are remotely level. I pumped out 5 plus quarts of engine oil and replaced with 5.5 quarts of Indmar 15w40 with new Indmar filter and fired engine. After letting set for several minutes, level looks very high. Like up into the dip stick tube high. The oil is perfectly clear and fresh looking, I do not believe any old oil had been left in the oil pan, which was my first concern. Before I had changed it, the old level of the dirty oil was at the top indicator on the dip stick like it had not used any.
  4. #4
    Join Date
    Feb 2016
    Location
    Boise, ID
    Posts
    1,419
    Quote Originally Posted by Brianrzr View Post
    The 5.7L is 5qt system so ya, you probably are a bit high on the stick. Shouldnt be crazy high though If you pulled out 5 qts. Fire the boat up and then check it after running. Some of that oil will "hangup" under the valve covers and you may get a reading that is closer to the full mark.
  5. #5
    Join Date
    Dec 2015
    Location
    Denver, CO
    Posts
    806
    Boat
    2007 22ve
    There’s always gonna be some residual oil you can’t get out unless you’re tearing the engine down completely. I always refill a half quart less than stated capacity, run it for 10/15 minutes, shutdown, let it sit for 10/15 then check it again and top off as necessary.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
