Results 1 to 6 of 6
Thread: Depth Gauge not Reading
  1. Depth Gauge not Reading
    I have a 2008 22ve and my depth gauge is stuck at displaying 3.3 feet. Does anyone know how to fix this or if there is a reset to the system?
    Thank you in advance.
    Jerry
  2. #2
    Join Date
    Mar 2016
    Posts
    361
    Boat
    Tigé
    Does your water temp and speed work on the gauges?
    It's dangerous to go alone! Take this.
  3. #3
    Join Date
    Sep 2017
    Location
    Minneapolis, MN
    Posts
    117
    Boat
    2018 RZX2
    Most likely a bad or dirty transducer. It is usually a black hockey puck looking item on the bottom of the boat near your water intake.
  4. #4
    Join Date
    Mar 2016
    Posts
    361
    Boat
    Tigé
    His would be a triducer. If he doesn't see speed or water temp, it could be a connection issue. If he sees both speed and water temp, connection is good, signal is going to CAN and ECM which means the depth portion of the triducer is bad. Unfortunately it requires a new unit.
  5. I can see speed and temperature
    Jerry
  6. #6
    Join Date
    Mar 2016
    Posts
    361
    Boat
    Tigé
    Sounds like the depth portion of the triducer is bad. Unfortunately the entire unit has to be replaced.
    The only other possible item is that the depth finder portion of the triducer isn't level with the hull. I doubt that's the case because you would see other values besides 3.3 feet but it is something to double check.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
