Results 1 to 3 of 3
Thread: Boat lift cables breaking!!
  1. Boat lift cables breaking!!
    Last year I had bought a used 5600 Hewitt Vertical lift for my R20. Towards the end of the year I upgraded to a 2017 Z1 and after a few times using the lift the spreader cables snapped (at separate times). When the first one went I ordered two factory cables because I knew the other side wasn’t a factory cable and figured it would break to. But I just put it on the lift for this year and I am very nervous they’ll break again.
    My question is how should the cables be tensioned. I have attached the diagram (mine has the winch cable going over and back due to it being a heavier lift). I’m thinking I may need to tighten the rear load cables but I’m not sure.
    Attached Images Attached Images
  2. #2
    Join Date
    Aug 2015
    Location
    Austin, TX
    Posts
    456
    Boat
    2015 RZ4
    Quote Originally Posted by dssteckm View Post
    I can’t help you on all of this. But I hate our cable lift. It scares the **** out of me every time I use it. I know they are completely safe when correctly fitted. But after seeing other hydro hoist style lifts in person, I’ve pretty much decided I’m completely done with it. The possibility of a cable or other piece breaking and hurting someone is just not worth it.
    Good luck with fixing this though. Free bump.
    BABz - babzusa.com
    Austin, TX
  3. #3
    Join Date
    Mar 2012
    Location
    Lake Minnetonka
    Age
    30
    Posts
    320
    Boat
    1999 Tige 21v Riders Edition
    I’m with BlackoutATX, not much hell but wanted to chime in. Our cable broke a couple seasons ago and the boat fell about 2 feet onto the water. It snapped right where the winch was. Granted it was 15 years old when it broke, it still scared the **** out of me and even more my wife. She had just stepped off of the boat onto the dock when it snapped. Talk about a close call.
    Now we always make sure to have everyone off the boat and on the dock before lifting the boat. After it has been lifted I will go back on to snap the cover on. Sometimes I get lazy and in a hurry and forget, but everyone with cable lifts be careful and inspect those cables and pullies!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
