Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Rzx2 vs rzx3 storage
  1. #1
    Join Date
    Jun 2017
    Location
    Canton , ga.
    Posts
    240
    Boat
    Z3
    Anyone with real world experience know the differences minor or major when these 2 boats are compared with storage room. Does the subfloor ballast give you that much more storage over the z3?
    If you wanna know what I did , come with me next time...
  2. #2
    Join Date
    Feb 2016
    Location
    Boise, ID
    Posts
    1,511
    I can't testify as to the rzx2 vs rzx3 as we just keep selling 3s. Can say that storage is day and night above a z3.
    I was just in the lockers putting PNP bags in an rzx3 today and I can comfortably bend down inside of them and could close the hatch panel on top of me if I wanted too. I'm 6'2" and 270lbs..
    When in a z3 locker I regularly have to slide my feet forward and under the seats to really get in there. If you'd like I could give you some actual dimensions. Koolaid probably can get an for you even quicker, or elevated may know right away as well.
    Regardless I'd say Apple's to Apple's the rzx2 and rzx3 have to be close in size, but the 3 has a deeper freeboard, which should mean more storage. Rzx3 compared to a z3 is like comparing apples to oranges...heck, Apple's to an avocado. Subfloor gives you a ridiculous amount of room, and as long as you run a smaller bag like a 600 you still have room for gear on top of the PnPs
  3. #3
    Join Date
    Aug 2015
    Location
    Salt Lake City, Utah
    Posts
    1,324
    Boat
    2017 RZX3, 2013 MB F24, 2000 21V
    Don’t forget about the rear locker storage of the 3. Meant for surf boards but storage is storage. Not sure if it’s water tight. Doubt it.
  4. #4
    Join Date
    May 2014
    Location
    Vancouver Island, BC, Canada
    Posts
    1,299
    Boat
    2016 RZX3, 2014 R20 with taps 3
    not sure if you've seen this. My experience with the z3 with full ballast you realy only have under the dash and the one bow locker.
  5. #5
    Join Date
    Sep 2013
    Location
    St. Charles, MO and Osage Beach, MO
    Posts
    531
    Boat
    2015 Z3
    The only way the Z3 has more storage than the RZX2 is if the ballast is empty! I agree with @bsreid
  6. #6
    Join Date
    Dec 2005
    Location
    Stuttgart Germany
    Posts
    897
    Boat
    Boat free till 2021 2016 Z3, 1998 2200v
    Yeah...Z3 sucks for storage if surfing. If surfing, I can stick a couple life jackets and a towel in the lockers. I tend to go out for 2-3 days at a time and just camp on the boat in the cove so storage is a premium. I do wish the Z3 had some subfloor ballast. For me, I just quit surfing and my enjoyment level and storage capacity went up.
  7. #7
    Join Date
    May 2014
    Location
    Posts
    1,299
    Boat
    If you can handle carrying more lead that might be an option to free up storage.
  8. #8
    Join Date
    Dec 2005
    Location
    Stuttgart Germany
    Posts
    897
    Boat
    Problem is you need about 600-800 pounds of lead plus all the bags to get the good wave. Adding a bunch of lead would be a total pain and pretty much make it a one trick pony.
    But that's the beauty of the Z3. If all you want to do is surf then it does that very well. If you could care less about surf then it does everything else as well as one could hope from a 23 foot Vdrive. If I have someone who really want to surf then I leave lockers empty so I can fill max ballast, throw in the lead and change out the prop...and it surf great. Although I have to say, 90% of the time they just hold the rope....which makes me wonder why I went to the trouble to rig for surfing for them.
    Anywho...back to original question. If you need storage and are big on surfing, you won't be happy with the Z3 storage.
  9. #9
    Join Date
    Jun 2017
    Location
    Canton , ga.
    Posts
    240
    Boat
    Z3
    Bsreid , where did you get those dimensions, why does it say rzx2 is best surf boat ? Is this true , better than rzx3?
  10. #10
    Join Date
    Jan 2004
    Location
    Mount Juliet, TN
    Posts
    2,555
    Boat
    Tigé
    Quote Originally Posted by Langwell View Post
    It is from Tige's website. You can compare different models.
  11. #11
    Join Date
    May 2014
    Location
    Posts
    1,299
    Boat
    I stole it off the website. The rzx2 was awarded best surf boar of the year. To answer your question some, yes some say it’s better.,
  12. #12
    Join Date
    Jul 2015
    Location
    Orange County
    Posts
    1,725
    Boat
    2019 ZX5/ZX1
    As others have mentioned the storage numbers are a little wacky as they list the storage in the Z3 that is technically un-usable when ballasted up. The Rzx line will have loads more storage room when using the boat with ballast given the numbers are regardless of whether the boat is full of weight or not.
    As for bow storage. In the Rzx2 you dont have any. The 2 has 2 250ish lbs bow bags that are true bow bags as they run to the very front of the nose. The Rzx3 on the other hand has 2 hockey stick shaped belly bags that run even with the observer/Driver seat. That means that the complete bow in the 3 is open and by open I mean the underseat storage can store 6 buoy's 7 vests, a throw, dock lines and my anchor set and 300 lbs of lead, and its still not full. If you want a massive amount of storage thats the boat to have bar none.
    All 3 boats surf awesome. The Rzx line is a significant step up in terms of sheer mass and size of the wave as well as power. Its not close and thats just because of physics. Much bigger bigger boats. For example a stock Rzx vs stock z3 has a drastic margin between the two. The Z3 will always release water a little cleaner.... We are doing quite a bit of testing in regards to how the plates are set in the RZX. We thought the difference was a sure fire hull thing, and while the z3 will prob always have a slight nudge in that department, we are getting the Rzx right there in terms of how clean the face is.
    Hope this helps.
  13. #13
    Join Date
    Jun 2017
    Location
    Canton , ga.
    Posts
    240
    Boat
    Z3
    Thanks , it all helps ! Surf wave to surf wave , rzx2 to rzx3 ....... let me know
  14. #14
    Join Date
    Jul 2015
    Location
    Orange County
    Posts
    1,725
    Boat
    2019 ZX5/ZX1
    The two are really close. The Rzx2 can truly be even weighted. The 3 needs a little lean. The 3 is a smidge longer. I love the Rzx2 wave though.
  15. #15
    Join Date
    Jun 2017
    Location
    Canton , ga.
    Posts
    240
    Boat
    Z3
    10-4 , sidenote.. does the rzx2 come with the 8inch in boats like the 3 or 6.5 like the z3
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
