Results 1 to 10 of 10
Thread: Remove ballast bags during winter ?
  1. #1
    Join Date
    Jun 2017
    Location
    Canton , ga.
    Posts
    139
    Boat
    Z3
    This will be my first winter with my z3 , i was curious if i should pull and drain the ballast bags during winterazation. Any input would be greatly appreciated, thanks guys.
    If you wanna know what I did , come with me next time...
  2. #2
    Join Date
    Jan 2004
    Location
    Mount Juliet, TN
    Posts
    2,440
    Boat
    Any
    It will help the boat dry out.
  3. #3
    Join Date
    Apr 2015
    Location
    Denver, CO
    Posts
    199
    Boat
    '17 Z3
    I pulled mine just to be sure there was no risk of freeze damage and to let everything stay nice and dry. I'll be converting all of the fittings to quick connects while they're out to make it easier, those front bags aren't the easiest to get out.
  4. #4
    Join Date
    Mar 2014
    Location
    Abbotsford BC Canada
    Posts
    628
    Boat
    2009 Tige 22ve
    I pull all mine to get all the water out and let the lockers fully dry. Also gives me a chance to wipe the bags down as they get a bit slimy on the bottoms.
  5. #5
    Join Date
    Sep 2013
    Location
    St. Charles, MO and Osage Beach, MO
    Posts
    479
    Boat
    2015 Z3
    I still have the dealer winterize, but we don't take ours out.
  6. #6
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    49
    Posts
    26,647
    Boat
    I would at least get all the water out of the sacs, especially those boats with Surf-XL (no sub floor hard tanks). Water left in the XL sac likely means water remaining in the drain pump. If you have older gen boats with the fly high style quick connects, I like to pull them and let the locker and sac dry as they sweat over the summer. If you have the tige sac without the quick connect fittings, at least fold them up or over the side as best you can and let everything dry before the long storage.
    Mikes Liquid Audio: Knowledge Experience and Customer Service you can trust-KICKER WetSounds ACME props ARC Audio FlyHigh Custom Ballast Clarion LifeForm LED Polk Rockford And More
  7. #7
    Join Date
    Sep 2017
    Location
    Minneapolis, MN
    Posts
    44
    Boat
    2012 RZ2
    Just pour about half gallon of RV Antifreeze in each bag, cycle your drain pumps until it spits out pink and you're good to go.
  8. #8
    Join Date
    Dec 2015
    Location
    Denver, CO
    Posts
    381
    Boat
    2007 22ve
    If you can pull them fairly easily do it then run both your fill and drain pumps to remove any residual water. Otherwise run some antifreeze through them as suggested above. If you don’t have quick disconnects nows a good time to install some. If I’m not using my boat for a week or two (god forbid!) I like to be able to periodically take them out and dry the boat out completely.
  9. #9
    Join Date
    Jul 2010
    Posts
    3,941
    Boat
    2009 24Ve w/ AutoWake, WakeTouch, and Ultra-Ballast
    Quote Originally Posted by BCRider View Post
    x2 on this. Plus you can use a shop vac to blow out the hoses and pumps once the bags are out.
    I also lift the sacs with one fitting at the lowest point to insure all water is out. Obviously they are not "dry" inside but no sense in letting an accumulation of lake water just sit in there.
  10. #10
    Join Date
    Jun 2017
    Location
    Canton , ga.
    Posts
    139
    Boat
    Z3
    Thank you guys for all your suggestions.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
