Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Taps 3 retrofit
  1. #1
    Join Date
    Dec 2015
    Location
    Denver, CO
    Posts
    381
    Boat
    2007 22ve
    Taps 3 retrofit
    Hey TO! I’m trying to find out if anyone is doing taps 3 retrofits anymore and if so would it be possible to do to a 2012 RZ2. Boat is Denver based but can travel if necessary to get it done.
    Trying to get some winter mods lined up!
    Thanks!
  2. #2
    Join Date
    Oct 2014
    Location
    Great Faces, Great Places--South Dakota!
    Posts
    890
    Boat
    Used to roll a major gangsta lean 24Ve; now a ballasted to the hills MB F24 with GoSurfAssist
    Elevated: your cue!
  3. #3
    Join Date
    Mar 2015
    Location
    Ogden, Utah
    Posts
    54
    Boat
    Tige Dealer
    If you don't mind towing your RZ2 to Utah, we could definitely do an install for you at Germaine Marine.
  4. #4
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    49
    Posts
    26,647
    Boat
    @Adam,
    A 2012 has Medallion Tige Touch 1, correct? How do you get it to show and control TAPS-3?
    Mikes Liquid Audio: Knowledge Experience and Customer Service you can trust-KICKER WetSounds ACME props ARC Audio FlyHigh Custom Ballast Clarion LifeForm LED Polk Rockford And More
  5. #5
    Join Date
    May 2014
    Location
    Vancouver Island, BC, Canada
    Posts
    669
    Boat
    2014 R20 with taps 3
    I just have the basic Lenco switches but if I were to do it again there’s a company making a controller that has memory settings and then fine tuning from there.
    I’ll try and find it
  6. #6
    Join Date
    May 2014
    Location
    Posts
    669
    Boat
    Here we go. Lectro tab makes a controller meant for surfing that has presets and fine tuning. Model: ALC-WAKE
  7. #7
    Join Date
    Sep 2008
    Location
    Helena,MT.
    Posts
    857
    Boat
    2017 RZX2 fully custom
    Not sure if the RZX2 plates would work but I have a set I’m gonna sell
    surf till u die.
  8. #8
    Join Date
    Mar 2015
    Location
    Ogden, Utah
    Posts
    54
    Boat
    Tige Dealer
    Quote Originally Posted by chpthril View Post
    @Adam,
    You are correct, on boats older without TT2 we install a Lenco switch on the dash to control the TAPS3 rams.
  9. #9
    Join Date
    Jul 2015
    Location
    Orange County
    Posts
    1,196
    Boat
    2018 Rzx2
    Quote Originally Posted by dakota4ce View Post
    Elevated: your cue!
    Adam has it. We can do it in Phx as well.
  10. #10
    Join Date
    Dec 2015
    Location
    Denver, CO
    Posts
    381
    Boat
    2007 22ve
    Thanks for the info guys!
    I had a feeling it wouldn’t integrate into the Tige touch on the 2012. I’ll touch base with Germaine and see what the options are.
    Bsreid-did you install a system on your R20?
  11. #11
    Join Date
    May 2014
    Location
    Posts
    669
    Boat
    Quote Originally Posted by Jetdriver View Post
    I had my mechanic do it. He said once he found the right position(based off Germaine’s recommendations and factory positions) it was no harder than trim tabs used on normal boats.
  12. #12
    Join Date
    Dec 2015
    Location
    Denver, CO
    Posts
    381
    Boat
    2007 22ve
    It’s definitely within the scope of my skills to do myself, it’s just a matter of wrangling up the right parts for the job.
    If I were to do it myself I’d want it to look and function as close to factory as possible. (Minus Tige touch integration)
  13. #13
    Join Date
    Aug 2015
    Location
    Salt Lake City, Utah
    Posts
    863
    Boat
    2013 MB F24, 2000 21V
    http://www.tigeowners.com/forum/show...hlight=taps+21
    If you haven't read through this, it should give you all the info you need as far as parts, etc.
    If I was to do this again, I would use wake logic to control the system. This will automate it and make it closer to actual taps 3.
    https://www.wakegarage.com/wake-logic-contact
  14. #14
    Join Date
    Dec 2015
    Location
    Denver, CO
    Posts
    381
    Boat
    2007 22ve
    Quote Originally Posted by UNSTUCK View Post
    Thanks Unstuck
  15. #15
    Join Date
    Jul 2015
    Location
    Orange County
    Posts
    1,196
    Boat
    2018 Rzx2
    Ill just float this out there.....
    Just slapping a plate in the water isnt the ideal way to go. I might work decent, but I truly believe you need to grab a plate that has some science behind it. Whether you buy a factory plate, or a 3rd party. Their is legit science behind the good ones.. trust me.
    As for a controller, the wake logic is for speed based deployment and retraction only. It is not a multi position capable system which is what is needed for true performing system boat.
    Feel free and call me and I can give you the run down on the systems that I would think about that arent even related or tied to Germaine. 714-306-3999
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
