Results 1 to 13 of 13
Thread: Underwater lights
  1. #1
    Join Date
    Nov 2016
    Location
    Union Michigan
    Posts
    137
    Boat
    2014 RZR
    Underwater lights
    Im thinking about installing underwater lights on my ‘14 RZR with Tige Touch. I have a touch option on the switch screen for the lights, can lights be wired to operate off that screen? I do not want to add actual switches. Thanks in advance for the feed back.
  2. #2
    Join Date
    Jan 2016
    Location
    Humble Texas
    Posts
    130
    Boat
    2016 R21
    Not sure about your year but on mine there were wires ran to the back of the boat. The lights were pretty simple to install if you dont mind drilling holes in the back of the boat. I believe the wires for the lights were blue and white.
  3. #3
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    49
    Posts
    27,242
    Boat
    Yes, no need to mount and wire a physical switch. However, you may have to enter the dealer mode and activate the switch. This is common among many brands these days with un-ordered factory options. The next thing to consider, what amount of load will the system handle? Its at least designed to handle the load of the factory lights.
    Mikes Liquid Audio: Knowledge Experience and Customer Service you can trust-KICKER WetSounds ACME props ARC Audio FlyHigh Custom Ballast Clarion LifeForm LED Polk Rockford And More
  4. #4
    Join Date
    Nov 2016
    Location
    Union Michigan
    Posts
    137
    Boat
    2014 RZR
    I have the VX hull extension, and I’m thinking about using a light that uses the drain hole. What type do you guys recommend?
    Attached Images Attached Images
  5. #5
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    49
    Posts
    27,242
    Boat
    I dont. Most are going to interfere with the movement of the plate. You may even find that you have to dismount the actuator to get it in and out. Lastly, taking the drain plug lights in and out leads to harness failure.
  6. I recommend this one, Blue or Green is really cool in water
    https://www.imarineled.com/27w-1800-...oat-light.html
  7. #7
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    49
    Posts
    27,242
    Boat
    Quote Originally Posted by williamG View Post
    @williamG
    Welcome to the forum. Tell us more about your boat that this light is on. Whats the clarity of the water you boat in. What do you recommend this light over others based on your experience?
  8. #8
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    49
    Posts
    27,242
    Boat
    Your site advertises that your lights have the lowest current draw in the industry. Sounds great on the surface. However, out in the field, we have found that current draw is the best means we have to gauge a light's brightness. So here's my conundrum. a 1A draw tells me your light is not bright at all. Although we dont put much stock in advertised lumens, your 1300 rating, puts it inline with lights we were using 10 years ago when the underwater LED as in its infancy.
    Ive stated my concerns with thread-in plugs lights in many threads, including this thread.
  9. Here is what it looks like with the boat, I'm satisfied with the brightness.
    Quote Originally Posted by chpthril View Post
  10. #10
    Join Date
    Apr 2006
    Location
    Lake Wylie area, NC
    Age
    49
    Posts
    27,242
    Boat
    @William,
    Who is Jeremy? He's over on wake world right this very minute passing that boat off as his. Also, that boat is found on an amazon sales add for some lights? Really your boat?
    http://www.wakeworld.com/forum/showthread.php?t=806612
    https://www.amazon.com/Anti-corrosio.../dp/B00QF073ZO
  11. #11
    Join Date
    Dec 2015
    Location
    Denver, CO
    Posts
    760
    Boat
    2007 22ve
    Quote Originally Posted by Brianrzr View Post
    There’s a couple write ups on mounting lights to brackets on the Vx plate so the lights are on the back of the plate and nothing is blocking their output. I think member Blackoutatx had a pair of shadow casters mounted like that that he swapped out to the new bad boy Liquid Lumens. He could steer ya in the right direction on the brackets.
  12. #12
    Join Date
    Aug 2015
    Location
    Austin, TX
    Posts
    415
    Boat
    2015 RZ4
    Quote Originally Posted by Jetdriver View Post
    I sure did. They worked great. PM me if it's something you think you want to try. Its not a hard job at all.
    BABz - babzusa.com
    Austin, TX
  13. #13
    Join Date
    Jul 2015
    Location
    Orange County
    Posts
    1,571
    Boat
    2018 Rzx3
    @William,
    CHP GOT EM!!!!!! Hes silent now. LOL
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
