Results 1 to 9 of 9
Thread: Help with starter
  1. #1
    Join Date
    May 2017
    Location
    Northern California
    Posts
    24
    Boat
    2003 v22
    Help with starter
    I have a 03 22v with MerCrusier 350 mag mpi...
    I believe the starter is part# 50-863007A1
    If this is not which on is, and what about using a aftermarket one?
    My plan is to replace, and have the old one serviced as a spare, or put the serviced one back in and have a spare, for the future weekends of boat troubles.
  2. #2
    Join Date
    Aug 2010
    Location
    Long Beach, CA
    Age
    42
    Posts
    988
    Boat
    1999 2100i
    Mercruiser #50-863007A1 is correct for the block mounted unit but if you have the top mount or rear mount it is #50-808011A05. The two are not interchangeable unless you remove the flywheel and change the position of the ring gear. I would advise against the cheap aftermarket units because they use circlip nose gear retainers. If the clip breaks it shoots the nose gear off and into the bell housing and your boating time is done until the unit gets replaced again.
  3. Question. My 09 22 ve motor went completely dead while idling on the lake. Everything else still working. Did I blow a fuse that I can't seem to locate?
  4. #4
    Join Date
    Apr 2011
    Location
    Tucson, AZ
    Posts
    252
    Boat
    2008 RZ4
    Dead as in nothing works at all? No lights, starter, stereo, dash stays dead when you turn on the key?
  5. Quote Originally Posted by dj2 View Post
    Everything works. Engine died and won't turn over at all now.
  6. #6
    Join Date
    Apr 2011
    Location
    Tucson, AZ
    Posts
    252
    Boat
    2008 RZ4
    Unfortunately it sounds like the starter solenoid. You can attempt to jump the starter to get you home, but this can be dangerous due to fuel vapor in the engine compartment
  7. #7
    Join Date
    May 2015
    Location
    Nixa, MO
    Posts
    22
    Boat
    2005 Tige' 22i
    Quote Originally Posted by jhinschberger View Post
    You can check the fuses in the engine compartment under the plastic "tige/vortec, 340HP" cover....small black box with fuses labeled. Philips head screwdriver to open. Just behind the bolt on the rounded side.
  8. #8
    Techna22v, I have the same motor and I put this starter in mine last year. 100 hours or so and still going strong.
    https://www.dbelectrical.com/product...lvo-penta.html
  9. #9
    Join Date
    May 2017
    Location
    Northern California
    Posts
    24
    Boat
    2003 v22
    Thanks Everyone new starter will be here this thur or fri... hopefully will be on the water sun as I have work sat...
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
