Results 1 to 13 of 13
Thread: NEW BOATMATE TRAILER
  1. #1
    Hey everyone! The time has come for a new trailer. The owner before me would pull out of the lake, pull his boat 1/2 mile, then put his boat up in an enclosed stall. The trailer would sit and rust for the next few weeks....Unfortunately, the main beam on the left side buckled today. I'm stuck till I get a new one. What's the best way about getting a new boatmate. Dealer or factory direct? I'm located between Austin and Houston TX. What can I expect to pay for a new one?
    Also, would yell recommend any other brands??
    Thanks in advance!!!
    Sent from my SAMSUNG-SM-T377A using Tapatalk
  2. #2
    Join Date
    Sep 2008
    Location
    Helena,MT.
    Posts
    906
    Boat
    2017 RZX2 fully custom
    Boat mate is the only brand I would ever run under my boats personally.
    There the best built and definitely stand behind the product so that be my vote all day everyday
    surf till u die.
  3. #3
    Join Date
    Mar 2016
    Location
    oklahoma city
    Posts
    61
    Boat
    2008 rz4
    I have a 1 year old boat mate and have already had many problems with lights not working , broken axle they told me that I hit something to break the axle and would not warranty it
  4. #4
    Join Date
    Sep 2008
    Location
    Helena,MT.
    Posts
    906
    Boat
    I've had 3 Tige's all on boatmates with 0 issues
    That's the first I've ever heard of a boat mate trailer failing
    surf till u die.
  5. #5
    Join Date
    Dec 2015
    Posts
    86
    Boat
    2005 Tige 22i
    Since you are in Texas, I would also look at a Magnum trailer. The Ski Dock uses them for some boat trailers. Heck they are just a few miles from the dealership in Austin.
  6. #6
    Join Date
    Oct 2012
    Location
    Jacksonville, FL
    Posts
    295
    Boat
    2012 RZR
    We just replaced our boatmate with the exact same one. Except this time its galvanized. The dealer had ordered it originally with painted steel and we use in brackish water about halt the time so it rusted pretty badly. Got 4 years out of it so I thought that was pretty good.
    We went through the dealer - Forte's in largo fl - great to work with. It took about 4 weeks and cost about $5000.00. Galvanized cost extra.
    I scrapped our old one and got $48.00 for it.
    I could have had an aluminum trailer built for $3200.00 but I have a garage issue and needed to be sure the boat would fit so I went with what I knew would fit. If I did not have that issue I would have gone that route.
  7. #7
    Join Date
    Feb 2008
    Location
    Lake Tapps, Wa
    Age
    43
    Posts
    5,642
    Boat
    Previous 2008 22ve. Current 2017 Z1
    Here's a couple photos of Boatmates quality. Trailer was delivered in March.
  8. #8
    Join Date
    Dec 2015
    Location
    Denver, CO
    Posts
    662
    Boat
    2007 22ve
    My 22VE is sitting on an Extreme trailer. It's built well and is real easy to load the boat onto. No major issues with it yet, I did replace the wheel well boards and carpeting.
  9. #9
    Join Date
    May 2014
    Location
    Vancouver Island, BC, Canada
    Posts
    982
    Boat
    2016 RZX3, 2014 R20 with taps 3
    My boatmate seems like a decent trailer. Starting to get some surface rust on the front hitch piece though.
  10. I have no problems with my Boatmate but I'm planning to sell it to my friend and then get a new one.
  11. #11
    Join Date
    Apr 2015
    Location
    Denver, CO
    Posts
    221
    Boat
    '17 Z3
    I just dropped my '17 trailer my dealer for brake issues. Boatmate uses a system of linked calipers to try and make the bleeding process easier -- in other words, the brake line daisy chains from one caliper to the next. The downside to this setup is that if you have a small leak or don't get a 100% bleed and end up with an air lock, all of the downstream calipers can have issues, instead of just one. In my case, with less than 1000 miles on the trailer, the right side brakes are squealing, rotors grooved, etc, while the left side looks brand new and never squeezed.
    All that said, the rest of the trailer and the build quality looks great on mine, I had no reservation going with Boatmate on our new boat, and I have full confidence that they'll make things right with this issue (I will definitely update if anything goes south).
  12. #12
    Join Date
    May 2014
    Location
    Clearwater FL
    Posts
    49
    Boat
    2008 RZ4
    I would never buy a Boatmate trailer (steel). Aluminum I-beam is the only way to go equipped with stainless steel Kodiak hubs, rotors, and pads. They use a unique axle unlike torsion or leaf that is far superior. http://rollsaxle.com/lifetime_spring.htm
    Do the electrical yourself and do it right. Tin coated copper (marine grade) wire, lead solder all connections, use 3M marine heat shrink tubing.
    You'll thank me later.
  13. #13
    Join Date
    Jul 2007
    Location
    Polk City, Iowa 50226
    Age
    47
    Posts
    1,508
    Boat
    08 RZ2
    I have a Ezloader trailer that came with my boat. So far I like it over my old boat which had a prestige trailer. It trailer nice an and far better to load on to also.
    I am having rusting issue but I believe that it's caused by previous owner , the the manufacture.
    15 Escalade ESV-Black
    08 RZ2-Blue
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
